ok so im running a hifonicz brz1200.1 amp and a 18" subwoofer on stock electrical with a added bat/cap and i think its time to do the big 3, i had a look under my hood and i was like wtf where do i connect the 0 gauge from the bat.. anyway would you pro's help me a out a little
so this is the stock
i will also change the terminals
thats the alternator there
and this is where the wires are going
i dont know what that is? is that a ground or something
Edited by pknubsalday
it might be a connector on the back of the alt. thats how mine was.. and it might be a ground mine looked similar. break out the ohm meter! (300th) post :yahoo:
BUILD LINK: http://www.stevemeadedesigns.com/board/topic/112034-2-sundown-18s-98-f-150/page__p__1565972__fromsearch__1#entry1565972
98 Ford F-150
Truck:
37" superswamper tsl radials
16" ion alloy wheels
3" body lift
2" suspension lift
Offbrand brushguard
PIAA driving lights
6000K HID's
System:
2 18" Sundown Nightshaed
Aq3500
Custom Fiberglass box
fosgate T1 6x8 Coxials
bass inferno 2000 watt 4 channel
2 XS power d3100's
0 Gauge
some vehicles have a separate ground on the alt. just find your charging post. if your alt has a few different posts just use a dmm to find the charging post.
2010 Subaru Impreza
Pioneer AVH-P1400DVD
2 10" Rockford Fosgate Punch HX2
Audison LRx 1.1K
superglue a dildo to the center of the cone....lube it.....then have that dumbass sit on it :good:
while playing a 10hz note
haha, this reminds me of a paintball sticker i have "my balls slap at 300fps"
now I want a sticker that says "i fuck at 10hz"
if it is a seperate ground should i use 0 gauge for it??
thread jack, but is it ok to do a big 3 on a stock alt? someone told me stock alts have pre set ground and power wires and its not ok to change them unless you buy a h/o alt. is that true? personally i think its bs
(UNDER CONSTRUCTION)
Kenwood KIV-700 headunit
2 18" sundown Z.v3s
13.5^3 wall tuned @ 28hz
SAZ-3500
DC power 270amp alt
JL c2 650
AP600.4
XS 1200 under the hood
XS 3100 in the trunk
1/0 gauge
big 3
25^2ft audio technix
^^ c-fuzzy ur an idiot, my 15" soround is waay bigger cuz its a tall sorround, on top of that I HAVE A BIGGER MOTOR... oh yeah and fuck u suck my dick i got your hoes!
anywhere they want to. They cant hear anyone telling them otherwise. just because its bigger doesnt make it any different. they just piss people off faster and farther away.
i dont think it is true..
it wouldn't hurt and sometimes it's necessary.
2010 Subaru Impreza
Audison LRx 1.1K
ive done it many times with no problems, some vehicles you have to leave the stock charging wire on. my friends 98 durango charging wire ties into his starter wire so we just added 1/0 to it with 1/0 grounds. it may make your lights dim worse cus after doing the big 3 the wires are no longer restricted so it allows more power to flow through.
2010 Subaru Impreza
Audison LRx 1.1K
  • Who's Online   1 Member, 0 Anonymous, 1732 Guests (See full list)
