ROAD_DOG Posted March 30, 2011 Report Posted March 30, 2011 hello people I would like to know if I would need any special harnesses for installing a system well as far as a cd player goes and replacing the stock speakers. If any one can give me a heads up on what ill be facing i will greatly appreciate thanks in advance..
ROAD_DOG Posted March 30, 2011 Author Report Posted March 30, 2011 to tell you the truth I dont know the car belongs to a cousin of mine but what is the out come if it has the bose system or not?
GSanders17 Posted August 31, 2011 Report Posted August 31, 2011 The radio will actually say Bose on it if it has a Bose system. Either way you will need a harness and dash kit to replace the radio. Getting the factory radio out is really easy, just pop the AC control panel off, disconnect the hazard switch and move the panel out of the way, then take out the one screw that panel was covering, then pull that panel off, then remove the four screws securing the factory radio. On a side note, if you are putting a double din radio in, the Scosche kit comes with plastic side pieces to secure the radio, the kit Metra makes only comes with the trim piece and requires you to use the factory radio brackets.
