Hey guys,
So I ended up having some issues with my D6500 second battery it wasn't getting charged as I had thought, It was only maybe used for 30 minutes or so without being charges, but it was taking around 2000 for that 30 minutes.
I need to charge the battery because the voltage was critically low. And I do not have an AGM battery charger.
My buddy said throw it on a regular battery charger for a few hours and then take it off.
So I put it on my battery charger and its been going for maybe 3 or 4 hours at 10amps and It should be about 14 volts I will go check it in a few with my multimeter.
Just wondering what I should do from here. I took it off the charger about 15 minutes ago to check its voltage and it read 12.5
Should I leave it charging at 10amps? The charger is a smart charger so when it sees a full charge it automatically decreases the amps down to a 1amp trickle charge. But still just looking to get some quick answers hopefully I didn't mess the battery up D:?
=@:noob::bull:
1/0 Power Wire All Around + Big 3 - $140
Rockford Fosgate T2500-1BD - MSRP $1800
(4) Memphis M3 10" Subwoofers 1600watts $300ea. = $1200
XS D6500 $245.65
PIONEER AVH-P5200DVD 7" Head Unit = $430
Soundstream SC-6T Component 6.5" FRONT $60
Pioneer TS-A1673R 6.5" REAR $85
A Bangin system! = PRICELESS!
Anybody?!
XS D6500 $245.65
Posted (edited)
12.5 volts is the resting voltage with car off? if so thats fine. the only time your going to see 14+ volts is in your car with the alternator charging or if you have a AGM style charger. hope that helped
Edited by REMT15
Yeah man it was really strange, I felt I wasn't getting the power I could on my trip home from work today which was only 15 minute drive, so the battery didn't drain much. But i checked it with my DMM and it read 8.6 so I was like WTF?! I ripped it out, took it to the shop and checked it again and it read 12.4 and I checked it with another DMM and it read 12.7 this was before i threw it on the charger. ( I must have checked the voltage and slipped off a lead when I measured in the car )
So I dropped it on a 10 amp 13v charge for eh id say about 5 or 6 hours I think I took it off at about 9 and started around 3:30 I think give and take some.
Either way when I took it off at 9ish it was resting at 12.6-12.7 which I believe is damn good! I am gonna check it again in the morning, I was just going to let it sit out of the car on the test bench ( not charging ) over night, and if its still at 12.7 I will throw it back in my car and start bumping again!
Hope all is well. Must have been a fluke.
Appreciate the reply! Will keep you updated in the morning.
XS D6500 $245.65
Well, Idk man. I charged it for a few more hours on a regulated charger so it ended up charging it at like 5amps for a few hours.
I took it off after about 3 hours and it was resting at 13.5
Hope thats not bad. LOL.
XS D6500 $245.65
