Elrey7698 Posted April 16, 2011 Report Posted April 16, 2011 I want to put a second battery in my truck cuz of all the dimming...i did the big 3 and it helped with the voltage but dimming is still an issue..i upgraded my alt from the stock 160 amp to a 200 amp that i bought off a guy with a diesel sierra 3500...the problem is that i dont know how to set it up...i have about 25 feet of 0 gauge left fom my big 3 setup...oh yeah i have a 08 yukon and im running about 2500-3000 watts...also mu truck has a second spot to put a battery... Quote
dkahns51 Posted April 16, 2011 Report Posted April 16, 2011 I want to put a second battery in my truck cuz of all the dimming...i did the big 3 and it helped with the voltage but dimming is still an issue..i upgraded my alt from the stock 160 amp to a 200 amp that i bought off a guy with a diesel sierra 3500...the problem is that i dont know how to set it up...i have about 25 feet of 0 gauge left fom my big 3 setup...oh yeah i have a 08 yukon and im running about 2500-3000 watts...also mu truck has a second spot to put a battery... http://www.stevemeadedesigns.com/board/topic/98509-how-to-properly-fuse-amps-and-rear-batteries/ heres a good diagram Quote **Clicky>>My 2009 Subaru Impreza Outback Sport Buildlog<<Clicky** I'm messing up 98% of the time
Elrey7698 Posted April 16, 2011 Author Report Posted April 16, 2011 Also my buddy works at autozone and he can sell me 2 optima yellow tops for 400 buck...is this a good deal? I know they are the highest cranking power they make and he says they run about 300 each... Quote
Kobieblu Posted April 16, 2011 Report Posted April 16, 2011 run a + line from front batt to + second batt with a fuse 8 inch away from batt 1 and 2 (so 2 fuses) , then groound wire from amp to 2 batt at the - post ground that same - post to body of the car somewere in the truunk wire negitive terminal from 1st batt to body as well run power wire from 2 batt to amp with fuse inbetween Quote RF love
dkahns51 Posted April 16, 2011 Report Posted April 16, 2011 Also my buddy works at autozone and he can sell me 2 optima yellow tops for 400 buck...is this a good deal? I know they are the highest cranking power they make and he says they run about 300 each... They are online for about $189... i bought mine at a Store in town for $189. So you should punch your friend in the stomach Quote **Clicky>>My 2009 Subaru Impreza Outback Sport Buildlog<<Clicky** I'm messing up 98% of the time
crunkjuice1 Posted April 16, 2011 Report Posted April 16, 2011 Also my buddy works at autozone and he can sell me 2 optima yellow tops for 400 buck...is this a good deal? I know they are the highest cranking power they make and he says they run about 300 each... For that $400 you can get an xspower D3100 battery Quote
Elrey7698 Posted April 16, 2011 Author Report Posted April 16, 2011 Also my buddy works at autozone and he can sell me 2 optima yellow tops for 400 buck...is this a good deal? I know they are the highest cranking power they make and he says they run about 300 each... For that $400 you can get an xspower D3100 battery That rat!!! I have a stock ac delco in the front...so should i just buy one battery and put it in the front or should i put it in the back? Quote
dkahns51 Posted April 16, 2011 Report Posted April 16, 2011 Also my buddy works at autozone and he can sell me 2 optima yellow tops for 400 buck...is this a good deal? I know they are the highest cranking power they make and he says they run about 300 each... For that $400 you can get an xspower D3100 battery ^^^^ better route I'm getting some XS powers for my 2nd battery when I do my Re-Build Quote **Clicky>>My 2009 Subaru Impreza Outback Sport Buildlog<<Clicky** I'm messing up 98% of the time
Elrey7698 Posted April 16, 2011 Author Report Posted April 16, 2011 Will that battery handle the cracking and the sounds at the same time?? What about kinetik...? They good? Quote
dkahns51 Posted April 16, 2011 Report Posted April 16, 2011 Will that battery handle the cracking and the sounds at the same time?? What about kinetik...? They good? Not my area of Expertise.. but go to the XS sponsorship page down the forum a little and there is alot of good things to read. Ohh and I hear Kinetik is poo.. don't know from experience though just what i read. Quote **Clicky>>My 2009 Subaru Impreza Outback Sport Buildlog<<Clicky** I'm messing up 98% of the time
