How would i wire 3 sets of components to a 2 ohm load? Should i even bother wiring them to a 2 ohm load? And should i use a four cannel for all six speakers?? I will be using Focal Access 6.5" 2 Way Component Speakers..
2002 Gmc Sierra 4x4
2 10" dual 2 ohm p3's
Custom box (34hz)
Kenwood eXcelon 1800 watt amp
Kennwood monitor
Polk Audio door speakers
Kenwood tweeters
Boston acoustics rear speakers
alpine 4 channel
How would i wire 3 sets of components to a 2 ohm load? Should i even bother wiring them to a 2 ohm load? And should i use a four channel for all six speakers?? I will be using Focal Access 6.5" 2 Way Component Speakers..
What impedance? I'm assuming 4 ohms? Also, what amp? If your amp is 2 ohm stereo stable, then you might be able to put one pair of speakers on one pair of channels, and one pair per channel on the other two.
POTATO!
Yea they are 4 ohms. I am gonna use the dc audio 175.4. So what your saying is put one pair of components on channel 1 etc.....??
2002 Gmc Sierra 4x4
Custom box (34hz)
Kennwood monitor
Kenwood tweeters
alpine 4 channel
Would i run a wire from the + input on left x over to the - input on right input and then run the other + and - to the amp?? If i did that i would have chan 1,2,and 3 taken but not chan 4??
2002 Gmc Sierra 4x4
Custom box (34hz)
Kennwood monitor
Kenwood tweeters
alpine 4 channel
  • Who's Online   0 Members, 0 Anonymous, 4729 Guests (See full list)
