Orion HCCA 15 box
I should be seeing a Orion HCCA 15 pretty soon and I'm going to want to build a box for it. I found the instruction manual and my dumbass can't see the inner port wall (L shape). I'm cutting pieces of paper pretending its the box but I'm still lost. I'm sure I'll be laughed at but still.
http://www.directeddealers.com/manuals/OG/Orion/GHCCA102%202008-11MLweb2.pdf
I'm looking at page 30 in link. Thanks for your patience.
ok I more or less made a rough drawing of a bow shape close to measurements using google sketchup and now I am at the poitnt where Im reading the port measurements, Do I just go to a side of the face side of box and pick a side and make a cut out of 4.5inW x 16inH?
it seems to me there are four individual pieces that make the port which I doubt but I'm lost none the less.
more box info,
— Box Parameters —
Vb = 3.05 cu.ft
V(total) = 4.491 cu.ft
Fb = 38 Hz
QL = 5
F3 = 29.47 Hz
Fill = none
— Vents —
No. of Vents = 1
Vent shape = rectangle
Vent ends = one flush
Hv = 16 in. (406 mm)
Wv = 3 in. (76 mm)
Lv = 26.62 in. (676 mm)
Sub info.
Fs (Hz) 33
Qts 0.6
Vas (cu ft) 2.648
Sensitivity 30dB
Mounting Hole Diameter (Inches) 15.6
Mounting Depth (Inches) 12
My space 38W x 22D x 19H max dimensions
