$320 + shipping.
1. Product:
Rockford Fosgate T1000BD-CP
2. Specs:
Constant Power Series Monoblock Class bD Car Amplifier
RMS Power Rating (14.4V):
4 ohms: 700 watts x 1 chan.
2 ohms: 1,000 watts x 1 chan.
1 ohm: 1,000 watts x 1 chan.
Dynamic Power Output: 1320 watts
Remote bass level input (Punch PEQ remote level control sold separately)
LED power (blue), protect (yellow) and thermal (red) indicators
Variable Bass Boost (0 to +18 dB bass boost at 45 Hz)
Gyrator based punch EQ eliminates frequency shift with boost
Mono channel operation
Audiophile grade speaker connections
Preamp Pass-Thru RCA outputs to daisy chain multiple amps
3-Way System Protection circuitry (thermal, overload, and speaker short protection)
Dual speaker terminals simplify the hookup of multiple speakers
Heavy duty cast aluminum convection heatsink with Direct Thermal Management evenly distributes heat across the entire heatsink for improved efficiency
Nickel-plated RCA level inputs
Nickel-plated clamp wire terminals
Input sensitivity:
Level: 150mV-5V
Variable low-pass filter (35-250 Hz, 24 dB/octave Butterworth)
Selectable Infrasonic filter (12 dB/Octave, -3dB at 28 Hz)
Damping factor: >200
CEA-2006 compliant amplifier
Frequency response: 20-250 Hz
Designed and Engineered in the U.S.A.
External 150A fuse required and sold separately
Dimensions: 13-11/16"L x 8-3/16"W x 2-3/16"H
3. Description/Condition:
Used for 2 months. Bought more subs, so i bought a T2500 instead. Perfect condition, was tuned by local audio shop to ensure no clipping.
  • 1 month later...
ttt
still for sale?
2006 Jeep Grand Cherokee LaredoPioneer AVH- 3200DVD2/0 Flex-A-Prene Welding Cable
(2) Fully Loaded Fi Sp4's dual 1-------> My YouTube Channel <-------
Needs more power those woofers will laugh at that turd
This topic is now closed to further replies.
