Sold please lock
I hate to let these go but im taking my build another direction. The amps are like new minus some minor scratches by the feet when mounted. The amps was bought at the end of Dec. the tested date can be read on the box in the pics,and was only used for a short time.The 3500 is still in my truck being used so please excuse the dirt. Not looking for any trades sorry.
$700.00+SH
Rated power output----RMS power, 2 ohm linkable/dual mono
7000W x 1CH----RMS power, 1 ohm mono
3500W x 1CH----RMS power, 2 ohm mono1750W x 1CH----RMS power, 4 ohm mono
750W x 1CHSignal to Noise Ratio>90dBLow pass frequency crossover35Hz~300HzSubsonic filter10Hz~60HzBass boost @ 45Hz0~6dBPhase shift control0~180 degreeFrequency response10Hz~350Hz (+/- 1dB)T.H.D @ 4 ohm<0.1%Efficiency @ 4 ohm86%Fuse rating300A (external type fuse)Input Sensitivity200mV to 6V (+/- 5%)Dimensions252(W) x 53(H) x 660(L)mm
$500+shipping
SPECIFICATIONS:
•Digital Class-D Linkable Mono Block Amplifier
•Double Sided Through Hole Epoxy PCB
•1 Ohm Stability
•Daisy-Chain Through Output RCA
•Efficiency : 86% @ 4 ohm, at 100Hz
•24dB/Oct Variable Crossover
•Multi-Way Protection Circuitry
•(Thermal/Over Current/Speaker Short/Speaker DC Protection)
•RCA Line Input and Master Output
•24dB Octave Crossover Slope
•24dB Octave Variable Subsonic Crossover Slope
•Variable Bass Boost
•Variable Low Pass Filter
•Variable Phase Shift
•Zero(0) Gauge Power Supply Connectors
•Tested Voltage & THD : 14.4V & Less than 1% THD
•Operating Voltage : DC 10V~18V
•Wired Remote Controller
Rated power output
5000W x 1CH
2500W x 1CH
1200W x 1CH
600W x 1CH
> 90dB
35Hz~300Hz
Subsonic filter
10Hz~60Hz
Bass boost @ 45Hz
0~6dB
Phase shift control
0~180 degree
Frequency response
T.H.D @ 4 ohm
< 0.1%
Efficiency @ 4 ohm
86%
Fuse rating
250A (external type fuse)
Input Sensitivity
Dimensions
252(W) x 58(H) x 512(L)mm
2011 Meca World Champ S3
Team Truth Hertz
Team DC
Working on my 93' Ford Bronco rebuild:
I have:
pioneer AVH-P6500
Infinity Reference 6032SI fronts
Infinity Reference 6832CF Rears
Crescendo CZ 6.5 kicks
Crescendo 1100.4
(2) DC Audio LvL 4 M2's
(1) Juicebox Blackcherry
Piece together amps & wiring
Bout to get:
Crescendo Amps
Crescendo Mids
Crescendo Tweets
Sky High Car Audio Wire
Rockford Fosgate 360.2 or .3
My Build
http://www.stevemeadedesigns.com/board/topic/97426-93-ford-bronco-rebuild-full-system-body-paint/
Just looking over ur specs u might want to retype them up, 2500w @1ohm, 5000w @ 2 ohms linked, great price though GLWS.
06 Impala SS
Kenwood Excelon DDX593
Ampere Audio 150.4
Ampere Audio 5K
1 XS D4700 (front)
Mechman 320a Alt. w/ Big 3
Lots of Second Skin Damplifier
Under Construction for 2017
Ah oops. Thanks for the heads up on that.
And why the Frown Scarface?
Team Truth Hertz
Team DC
Open to offers. But im not looking for any trades at the moment.
All boxed up and ready for a new home!
Team Truth Hertz
Team DC
ttt
Team Truth Hertz
Team DC
ttt
Team Truth Hertz
Team DC
Ttt
Team Truth Hertz
Team DC
