i have a 2008 dodge mag fixing to start building it. trying to get questions answered before i tear it down.
the alternator is in the front of the car and batt is in the back under the cargo floor. goin to do the DC high output alt. and want to know how i should work the big 3 upgrade? also do i have to buy the module for my car to let the alt put out 14.4+ or is it goin to do that when i hook it up with out the module?
if any body has some good ideas or a diagram of what they did i would greatly appreciate the help
run the 1/0 from the alt to the back 1/0 ground from alt body to body of car I put mine on the factory ground lug then in the back 1/0 ground to the factory ground lug thats how mine in my 300 is done
06 chrysler 300C Hemi
one mmatts dreadnaut 15 powered by a planet audio vx 2200d
fosgate p200 running planet audio 8" midbass drivers and super compression tweeters
stock battery and a stinger spv44
Irragi 300 amp alternator
big 3 1/0
http://www.stevemeadedesigns.com/board/topic/55075-system-in-my-300c/page__view__findpost__p__763656__fromsearch__1
that module your talking about just boosts the voltage that your alternator creates. not really needed for a regular audio setup though. IIRC (dont quote me on this) but i think dc alts are set to 14.8v or somewhere around there straight out of the box so no voltage booster is really necessary
edit: some cars have the voltage regulated by the PCM and not the alternators voltage regulator but i dont know enough about it to give you a solid response on that.
Edited by Kranny
So you would use the module with factory alt to boost voltage. How much boost does it give?
you dont need it the chryslers and dodges have a module that keeps the voltage there already mine has no dimming unless I wang on it hard with some very hard hitting bass but it only does it a little bit at first hit of the note but I have a small second battery and still using the factory batt when I do a battery upgrade I hope that goes away god luck with your build post up picts and vids everyone loves those here if you haven't figured that out yet :good:
big 3 1/0
^^^^^ I'll check it out. Thanks I'll hit you up if I see anything else.
  • Who's Online   0 Members, 0 Anonymous, 948 Guests (See full list)
