crazyeight Posted July 12, 2011 Report Posted July 12, 2011 I was wondering if you run 1 positive wire from your alt to the battery should you run the same size ground from the Alt to the chasis?
LoudBurp Posted July 12, 2011 Report Posted July 12, 2011 I was wondering if you run 1 positive wire from your alt to the battery should you run the same size ground from the Alt to the chasis? more often then not, yes. See you could test everything to see what the smallest ground you could run is. But, typically you want your grounds to be the same size if not bigger. Grounding is the key to it all. Best of Luck and Cheers! There is a point of diminishing returns on the amount of equipment installed, kinda like throwing money out a window.
