audio1der Posted July 22, 2011 Report Posted July 22, 2011 -Is the neg(-) Front-Rear run between batts as important as the positive, instead of relying on the chassis as a single common ground? -If you had 2gua and a 1/0 runs F-R with stock alt, upgraded front batt and large batt in the trunk for an Audioque 1200 (at 4ohm for now) and a PG M-50 how would you use them? If I have to do another F-R run I may jump off a bridge; it's REALLY difficult in such a small car. I had envisioned using both runs for +Pos, but am now reconsidering. Opinions would be appreciated. -Kevin Big 3 with 1/0 welding cable, dual runs of 1/0 and 2gua F-R DD 2512 D2 powered by Audioque 1200d at 1ohm, 2.5ft^3 ported to 36Hz Boston SX 6.0 comps powered by Phoenix Gold M50 for front stage Silver Flute 8" midbass in doors powered by Alpine 3539 Alpine CDA-117 HU
