Was wondering what others thought about it.
Right now mine is running 4 subs.
2x JL Audio 12inch W3s (SVC)
2x Memphis Audio 12inch PRs (SVC)
Bridged down to 2 ohm @ 400watts
Its more than is recommended for all of the subs but I keep it all down low enough to run fine. So far it's been good, a little flakey when it comes to tweaking the settings. Has some heat issues but aslong as you keep it where it gets good air flow then its all fine.
So has anybody else used this amp or currently using it?
you mixed your subs cause why?
225HP 1996 S-Dime
JVC KD-G820
Crunch PZi 2250 powering Two Ascendant Audio Assassin 8s wired to 2 ohm at 225W RMS 2.26CF @ 36.4Hz 43.5 square inches of port with 45's
Kicker ZX350.4 powering CDT CL-61A's with TW-24 Tweeters
Contact me:
AIM: Necromancer Ku
YIM: Ku_Karukasa
MSN: [email protected]
Well originally I only had the 2 PRs and then I got an offer to buy the 2 W3s + box for $400 and took it. I'm currently selling the 2 PRs and the box they are in to buy 2 more W3s but until then its nice having a system that will bounce change on my roof :)
Guest Nismofreak
using it....IT SUCK SO SO SO BAD
not sending clean power to anything.....bad amp....If I where you look into the blade series amp which are so much better....chacos ftl boss audio ftl now I will replacing my dads system with hifonics and mb quart with dc audio subs
opps boss audio ftl lol
Edited by Nismofreak
not sending clean power to anything.....bad amp....If I where you look into the blade series amp which are so much better....chacos ftw boss audio ftw now I will replacing my dads system with hifonics and mb quart with dc audio subs
Yeah im gonna be getting a new amp tomorrow after work, will probably be running 2 so I can control the 2 types of subs better
  • Who's Online   0 Members, 0 Anonymous, 639 Guests (See full list)
