Help with crossover/LOC
Hey everyone, I'm new to the boards so before I post my question allow me to introduce myself. Name's Ben, and I have a fair knowledge of electronics and system installation (i installed my system in my old car with and aftermarket kenwood headunit. I just got a new car, with a cd changer and would like to keep it so i'm kinda forced to do things the hard way.
Anyhow,I'm running into some problems here and a buddy of mine sent me here. Here is what I'm trying to do. I have a 2004 Sebring Coupe and am using the stock headunit (i want to keep my integrated 4-disc changer). I have a Pioneer 760w 2-channel amp and a single pioneer 1200w 12" sub. I asked one of the car audio shops here in town about how to hook into a factory system and the guy sold me the Legacy LXR-1 crossover with both high and low level speaker inputs and RCA outputs. I tapped into the rear deck speakers using quick splice connects and ran the new leads down to the +/- high level input for the corresponding side (right/left). I then hooked up a power lead from the amp wire coming off the battery, and a ground lead from the amp off the grounding bolt to the crossover in the perspective spots. I also hooked up a lead from the REMOTE on the crossover to the System Control (Remote) on my amp and then finally RCA outputs from the crossover to the amp. All this and STILL NO POWER to the unit (or at least is isn't powering on). I ran a test light to check connectivity and here is my results:
12v+ (battery) to 12v+ (amp) = good
ground (chassis) to ground (amp) = good
12v+ (amp) to 12v+ (crossover) = good
ground (amp) to ground (crossover) = good
remote (crossover) to remote (amp) = nothing (car on/off...doesn't matter)
speaker leads (rear deck) to speaker input (crossover) = good
I tried one last thing before giving up...and that was jump the circuit from the + on the speaker inputs to the remote on the crossover and magically the unit powered up, but still didn't power on my amp. After I failed in every which way i could imagine, i just disconnected the wires, taped them off so they don't ground out in my truck and stopped. Does ANYONE have any idea, what may be going wrong here and ANY idea on how to fix it?? Any help would be much appreciated, thanks!
-Ben
do you have a switch to switch on the power to the amp and crossover/loc? if so, are you sure its wired correctly?
when i had the system in my old car it was switched...but with this, no there is no switch. should power up when car is placed into accessory or on position but i got no juice
try to take a wire from 12v to the remote and see if it turns on, if not. you have wired it wrong. or your battery isnt big enough..
Cerwin Vega <3 . When Bass Counts!
