I have 2 Dayton Audio Classic series 18" Subwoofers up for sale. They are both single 4 ohm. Got them about 2 weeks ago planning on a home audio setup, but im just really needing the monies back right now. Neither of these have seen true power... all i did was rub a 9 volt across each subs terminal to make sure they work... both did! Would like to do 200 + 1/2 shipping. Or possibly a trade for a 2000+ RMS amplifier. LMK if you want any other info.
Specificaitons: • Power handling: 300 watts RMS/450 watts max • VCdia: 3" • Le: 2.96 mH • Impedance: 4 ohms • Re: 3.2 ohms • Frequency range: 22-500 Hz • Fs: 25 Hz • SPL: 94 dB 2.83V/1m, 91 dB 1W/1m • Vas: 9.90 cu. ft. • Qms: 5.64 • Qes: 0.51 • Qts: 0.47 • Xmax: 8.25 mm • Dimensions: Overall diameter: 18", Cutout diameter: 17", Depth: 6-7/8".
Edited by 99xtremedime
a0xp5g.jpg-2 AQ HDC3 15's-'Nendo 3KWP @ .5-7.75cuft @ 30hz-Alpine CDA-117-4 Cadence PA 8's
-AQ 200.2-2 AQ Supertweeters-XS Power D3400-270a Mecman Alt
-Knu Konceptz Wire
This topic is now closed to further replies.
