warm subs and not enuff beat
I give up
If they are black coils or smelly coils then you hurt them.
If they all ohm out the same then keep using them.
But if your still having issues with wiring them, then just have a pro wire them up for you.
Wiring 4 subs, can be tricky if you dont take your time... one wire WILL mess EVERYTHING up...
ive done many 4 sub set ups...once i wired ONE sub out of phase, took me a good hour to figure out i mis-labled a wire wrong.
1998 gmc extd cab
12 crossfire C710s
4 SAZ-4500s
3 Singer 400A alts
buncha mids/highs
Team Asshole
how would i go about checkin out the amps? im about 95% sure my master amp is ok, as i had it running 2 subs earlier and seemed to be working correctly, now when i wire up the other 2 subs to the slave amp. (note i un did strapping and basically gain matched both amps) and still had a issue with subs not sounding correctly. so i would assmue theres a issue now with the slave or 2nd amp?
if your subs wernt wired corectly...then they will sound differnt.
1998 gmc extd cab
12 crossfire C710s
4 SAZ-4500s
3 Singer 400A alts
buncha mids/highs
Team Asshole
on each amp i ran 2 subs all coils parrelled for 1ohm load
  • Who's Online   0 Members, 0 Anonymous, 1751 Guests (See full list)
