Pages 1-3 are of the box build. Pages 4+ have the new equipment and install
Equipment: (some of it has been replaced - see page 4)
Power is stock battery and alternator.
1 farad cap (now removed)
4 gauge wire
2 MTX TR7512 (500W RMS)
MTX Jackhammer JH600 Amp (replaced)
Sony DSX-S200X Media Player
Box:
40"W x 16"H x 23"D
5.2 cu. ft. Net
Subs up/Kerfed Port Back in center
70 sq. in. port area (14" X 5")
Tuned to 33 Hz maybe 32.
Now for the pics
Headunit - Sony DSX-200X
Subs - (2) Modified American Bass 18's
Monoamp - DD M4
Front Stage - CDT HD62-AS components with
4 Crescendo PWX 6.5
4 Channel Amp - Hifonics ZRX1000.4
Cadence 0 gauge
Singer 275 amp Alt
D7500 XS Power battery
Quad 1/0 input Toolmaker terminals
SMD OM-1
RGB LEDs
BUILD LOG CURRENT ABOVE SETUP http://www.stevemeadedesigns.com/board/topic/191602-2003-bravada-2-18s-ab-dd-xs-singer/
BUILD LOG (2 MTX 7512's)http://www.stevemead...__fromsearch__1[/size]
Replacing this 3.8 cu. ft. sealed box.
Monoamp - DD M4
4 Crescendo PWX 6.5
Cadence 0 gauge
Singer 275 amp Alt
SMD OM-1
RGB LEDs
Initial T-vider design with 1/4 round PVC and rounded edges.
Monoamp - DD M4
4 Crescendo PWX 6.5
Cadence 0 gauge
Singer 275 amp Alt
SMD OM-1
RGB LEDs
After some research I decided to modify it to separate the two waves and get them more directed down the port. Stuck a piece of 1/4" paneling between them.
Monoamp - DD M4
4 Crescendo PWX 6.5
Cadence 0 gauge
Singer 275 amp Alt
SMD OM-1
RGB LEDs
Cuts for tapered port outlet.
Anyone wanting to bend MDF with this method, the key is very thin cuts. There are formulas or trial and error to figure out the rest.
Monoamp - DD M4
4 Crescendo PWX 6.5
Cadence 0 gauge
Singer 275 amp Alt
SMD OM-1
RGB LEDs
Just some primer
Had someone stop by and thought I was building a two holer outhouse.
Monoamp - DD M4
4 Crescendo PWX 6.5
Cadence 0 gauge
Singer 275 amp Alt
SMD OM-1
RGB LEDs
Starting to attach front kerfed panel to bottom (which is standing vertical)
Monoamp - DD M4
4 Crescendo PWX 6.5
Cadence 0 gauge
Singer 275 amp Alt
SMD OM-1
RGB LEDs
Cuts glued and kerfed panel secured
Monoamp - DD M4
4 Crescendo PWX 6.5
Cadence 0 gauge
Singer 275 amp Alt
SMD OM-1
RGB LEDs
Looking at front of kerf port opening. I couldn't find any thinner blades for my circular saw which is why the cuts were stressed and show through.
Monoamp - DD M4
4 Crescendo PWX 6.5
Cadence 0 gauge
Singer 275 amp Alt
SMD OM-1
RGB LEDs
Top view of bend glued
Monoamp - DD M4
4 Crescendo PWX 6.5
Cadence 0 gauge
Singer 275 amp Alt
SMD OM-1
RGB LEDs
