Adding a second battery
Im going to be adding a second battery in my car, located in the trunk, i have a Optima D34 yellow top up front and want to put a second one in the trunk. Stock Alt is 120 amp and from what ive been told it should be sufficient in charging these two batterys.
Im running 2 MTX 9500's on 2 MTX 81001 amps rated at 1000rms each (birh cert shows just over 1300rms) at 2ohms each.
There is also 2 Rockford p200-2's and a Jl audio 300/4 amps. A RF 3sixty.2 is also in the mix.
Front battery ground has been upgraded and ive done the Big 3 all in 0 gauge.
Is adding this second battery going to cause any problems and if not is it sufficent to run these amps properly??
What do you guys reckon??
Rockford Fosgate 3sixty.3
Front stage - 2 x RF P2 8" midbass 6 x jl audio c5-650 mids 4 x Hertz HT28 Tweeters
JL audio 300/4 amp
Rockford Fosgate 800-4AD amp
2 x MTX 9512-44 Subs
2 x MTX 81001 mono amps
2 x Optima D34 Yellowtop
Stinger HPM 0 Gauge
  • Who's Online   0 Members, 0 Anonymous, 1231 Guests (See full list)
