zakmmm Posted September 5, 2011 Report Posted September 5, 2011 OK so as of now I have: 2 Audioque HDC310's 1 Audioque AQ2200 4 Kynetic KC600's So I am going to add one more AQ2200 to the set up and I'm not real sure how much more power I will need for this upgrade? I was thinking either single H/O alt or duel alt setup and adding another 2400amps of battery. Any help would be appreciated!
Impalaspl Posted September 5, 2011 Report Posted September 5, 2011 I would look into DC power alts and look into a XS Power D3400. I would do dual 280 or 240 amp alts. Hope this helps!
Guest Posted September 5, 2011 Report Posted September 5, 2011 I would look into DC power alts and look into a XS Power D3400. I would do dual 280 or 240 amp alts. Hope this helps! why does he need 2 alts for a 2000w amp? a single 200-300amp alt will do perfectly fine when paired with a D3100
Impalaspl Posted September 5, 2011 Report Posted September 5, 2011 beacause he is looking at getting another 2000 watt amp.
zakmmm Posted September 5, 2011 Author Report Posted September 5, 2011 beacause he is looking at getting another 2000 watt amp. Correct I will be running two of the AQ2200's and I wasn't sure if i would be better off running two alt's (one for my trucks electrical and one strictly for the system) or one to run the whole thing.
Impalaspl Posted September 5, 2011 Report Posted September 5, 2011 I would go ahead and get two to be safe bc thats already 4400 watts rms just for subs. I would look into a XS power battery...i have one its all around awesome. What amp is running your mids and highs?
zakmmm Posted September 5, 2011 Author Report Posted September 5, 2011 I would look into DC power alts and look into a XS Power D3400. I would do dual 280 or 240 amp alts. Hope this helps! I am going to keep the 4 KC 600's on the one amp because they perform well and just adding the same setup for the new amp was what I was thinking. This is a daily driver truck and my space only allows certain size batteries.
Impalaspl Posted September 5, 2011 Report Posted September 5, 2011 ok i understand...well good luck to you!
zakmmm Posted September 5, 2011 Author Report Posted September 5, 2011 I would go ahead and get two to be safe bc thats already 4400 watts rms just for subs. I would look into a XS power battery...i have one its all around awesome. What amp is running your mids and highs? No amp running mids and highs. The truck has factory Bose and it sounds great at the moment. We will see how they do when I add the second amp!LOL
