DC Sound Lab
Smaller box more control with a lot of power. Bigger box more efficient with less power. You should be fine matt. Wire that 7.5 down low and put up some big numbers
Got mwspl finals next weekend, the subs are d2 got them wired to 2 onm. Subs new just out of box. Was going to wire them down to .5 ohm for finals. I'm doing a burp class and a music class, you think the subs will be fine at .5 ohm for the music run. It's a 30sec run?
TEAM DC AUDIO
1999 Tahoe
HU-Clarion flip out
& Clarion EQS746
Mids/Highs Amp-MB QUART ONX4.125
Mids/Highs- Undecided
Sub Amp-DC Audio 7.5
Subs-4x DC Audio xl 18s
Alt- 270sp & 250sp Dc Power
Big 3 1/0
http://dcaudio.us/
SPL-LAB sells rep. for IOWA
http://spllabusa.proboards.com/
TEAM DC AUDIO
1999 Tahoe
HU-Clarion flip out
& Clarion EQS746
Big 3 1/0
http://dcaudio.us/
Totally different boxes but I ran my 2 xl18s off a sd8k@1 ohm in bass boxing so I did 3 30 second runs back to back on a pretty warm day but at the end of my 3rd run they were warm and a hint of smell. They were in a 6th order though.
Those 3 runs were after lots of demos and 3 db drag runs.
1993 toyota pickup
head unit- kdc-x994
mids- jl xr 3ways with extra set of 6.5s
mids amp- nothing special yet
subs- 2 dc lvl6 m2s
sub amps- 2 dc 5ks
alts- 2 stock chevy ad244s
batts- 5 amg g31s & 1 amg g24
TEAM DC AUDIO!
TEAM NWSPL!
Set gains properly play a song that's a lil above your tuning and you should be fine. For example I peak at 37hz and burp there. But when I do my p&p run I use airforces which peaks at 41-42 hz its easier on my electrical and is louder than juicebox which is 38hz
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
Dc98hoe what is you box turned to and what kind of # you put up?
Not sure its been so long I think 36-37. And my best number is a 156.1sealed on the glass @38 and 54s on music
TEAM DC AUDIO
PREAMP:arcaudio
SUB AMP: 2-dc7.5s
BATTERIES:6-d1400s
  • Who's Online   0 Members, 0 Anonymous, 4204 Guests (See full list)
