Guest Posted September 28, 2011 Report Posted September 28, 2011 i'd check for loose wiring on that alpine Power Pack. my first guess if you say it only happens to the speakers and not the subs. Quote
zach2323 Posted September 28, 2011 Author Report Posted September 28, 2011 good idea ill check that power pack first thing tomorrow. idk why i haven't yet... And I've had this setup exactly as is for months now so the ohm load should be fine. Quote
audio1der Posted September 28, 2011 Report Posted September 28, 2011 How do you have 6 alpine 4ohm 5x7 speakers powered by an Alpine HU? Is the HU rated for 2 ohm loads? If not, it might have put up with the load for a while, but has had enough. Quote Big 3 with 1/0 welding cable, dual runs of 1/0 and 2gua F-R DD 2512 D2 powered by Audioque 1200d at 1ohm, 2.5ft^3 ported to 36Hz Boston SX 6.0 comps powered by Phoenix Gold M50 for front stage Silver Flute 8" midbass in doors powered by Alpine 3539 Alpine CDA-117 HU
zach2323 Posted September 28, 2011 Author Report Posted September 28, 2011 How do you have 6 alpine 4ohm 5x7 speakers powered by an Alpine HU? Is the HU rated for 2 ohm loads? If not, it might have put up with the load for a while, but has had enough. yes it is rated for 2 ohms. and how I have 6 is the back wall wire is spliced to have 2 speakers each back channel instead of 1. Quote
