PUNKYOU007 Posted September 30, 2011 Report Posted September 30, 2011 So there are 14 8 ohms speakers total. I want 7 on each channel with a 2 Ohm final load. Look at my diagram and either correct me or confirm it is correct please. So there are 8 8ohm speakers total. I want 4 on each channel with a 4 ohm final load. Look at my diagram and either correct me or confirm it is correct please. I actuall came up with 3.2 ohms final but I am ok with that. Doethepaperboy "Bars of Pain" Doethepaperboy "Hero Remix" C. Arson d(-__-)b beer sucks...but i can bring some jose cuervo. Only problem is that it makes me horny and gives me the rams. So unless yall wanna fight and then have some great make up sex i will leave it home.
AA98hoe Posted October 1, 2011 Report Posted October 1, 2011 The 2nd pic it looks like you only have 2 subs series that won't work. You series a pair twice then parrallel it will give you 8 ohm load or you parrallel 4 and get a 2ohm load TEAM DC AUDIO VEHICLE:98 chevy tahoe 2wd 3-4 drop HEADUNIT:alpine 9886 PREAMP:arcaudio FRONT STAGE:4-6 1/2s selinium,DD component set and 4-selinium tweeters in each door KICKPANELS:jl audio 5 1/4 REAR DOORS: dd components 6 1/2s HIGHS AMPS:zapco 750.2 on front doors,zapco an another 750.2 on kicks and rear doors SUBS:4-ascendant audio 18s with 5 spiders in a custom box built by KINGSUV SUB AMP: 2-dc7.5s ALTERNATORS: 3-mechmans 1- 425comp, 1-smd spec350, 1-270 with adj voltage harness on custom dc bracket WIRE:10-runs 0g front to back BATTERIES:6-d1400s TL results:157.1 at 38hz and 156.8 at headrest score @37hz. STATE AND NATIONAL RECORD IN MECA S5.
PUNKYOU007 Posted October 1, 2011 Author Report Posted October 1, 2011 Why can't I series one pair? They are supertweeters also, btw Doethepaperboy "Bars of Pain" Doethepaperboy "Hero Remix" C. Arson d(-__-)b beer sucks...but i can bring some jose cuervo. Only problem is that it makes me horny and gives me the rams. So unless yall wanna fight and then have some great make up sex i will leave it home.
