ok so my budgget is £250 so far i have
JVC KS-AX5602 Bridgeable 800W Max 2 Channel Power Amplifier
specs:Bridgeable 2 Channel Amplifier
Max Power: 800w
RMS output: 2 x 150w @ 4 ohms
RMS output: 1 x 300w @ 4 ohms Bridged
Frequency Response: 5 - 50,000Hz
sub:
Kicker Audio CompVR CVR12 CVR
Size: 12" (305mm) CompVR 2 Ohm Subwoofer. Cone Material: Inject-molded polymineral.
Dual Voice Coil: Yes. Sensitivity: 86.5 dB. Frequency Response: 25 - 500 Hz.
RMS Power Range (Watts): 400. Max Peak Power Handling (Watts): 800.
Top Mount Depth (inches): 6 5/16".
Cutout Diameter or Length (inches): 11 1/8".
and i thought i would make my box
my question is have you got any good tips for making a box and dose this build work if you want the links i can send you them this is my first build for my bedroom then car and boot space isnt a problem,i want a t-line box and my school has all the tools i can use so can you help me im a noob at building and what do those cylinder things do there called capastiors or something i have just seen them with little led screens showing voltage or something
