Hello
Just bought this amp for a good price, and wondering if it's any good? Condition of it is really good, and inside is clean too.
From doing little research i found out that it's rated:
Output Power at 20Hz 20kHz:
4 x 35W @ 4 or 2 ohms
2 x 70W @ 4 or 8 ohms bridged
THD: <0.1% (20Hz 20kHz, full power, 2, 4 or 8 ohms)
S/N Ratio: >100dB
damping Factor: >200
Max. Current Draw: 45A
Question is, how do i hook speaker up to it? Do i need to buy crossover too?
also found these specs:
4 Channel - 35~ x 4,20Hz-2OkHz, into 4 ohms
3 Channel - 35~ x 2, plus 9&v x 1,2OHz=20kHz, into 4 ohms
2 Channel - 90w x 2,2OHz-2OkHz, into 4 ohms
Not sure which one's are right
You have a real nice sq amp for low power, its 35x4 at 4ohm and 45x4 at 2ohm it was one of the best amps that thay made nice sq but dont make alot of power sounds nice with some good comps, you can send it to me and i will take good care of it for you... :yahoo:
lol I need 2 channel amp, so i'm guessing it's 90wrms @ 4ohm? What about gains and other stuff, how do i tune that? btw, payed $8 for it.
Who did you take that from? Great amp. Very clean power and underated.
98 Chevy Blazer 4 Door
Stock Everything
The New Setup
1 - Pioneer AVH-P5200DVD
1- Pioneer DEH-80PRS
2 - Blues Audio 5.25 Mids ( On the dash )
2 - Blues Audio BL8.0C Components ( In the front doors )
2 - Blues Audio BL8.0 Woofers ( In the rear doors )
1 - Linear Power 952 ( Dash )
1 - Linear Power 2202IQ Modified ( Components )
1 - Linear Power 3002 ( Rear Doors )
1 - SoundStream XBP-10 Processor
1 - SoundStream BX-20Z
2 - SoundStream DTR1.3400D
4 - RE Audio SX12D4
That amp was like 300 back in the day. Run a active xover to it
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
See the lil black gain pots on the board there should be holes in the heatsink for them that's the gain left and right for each channel
TEAM DC AUDIO
PREAMP:arcaudio
SUB AMP: 2-dc7.5s
BATTERIES:6-d1400s
On button there are 2 switches " mono" and "Stereo" for A and B channels .
What's the active xover? never ran it before, but heard of it.
  • Who's Online   0 Members, 0 Anonymous, 1126 Guests (See full list)
