Vi sound Posted October 19, 2011 Report Posted October 19, 2011 Hey I have a question for anyone , Can I run my power wire from my alt to the my battires in the back insted of from the battire under the hood to charge then or not ?
AA98hoe Posted October 19, 2011 Report Posted October 19, 2011 Yes but why not use the reserve from the front also? If you did big 3 it will still pull from front battery TEAM DC AUDIO VEHICLE:98 chevy tahoe 2wd 3-4 drop HEADUNIT:alpine 9886 PREAMP:arcaudio FRONT STAGE:4-6 1/2s selinium,DD component set and 4-selinium tweeters in each door KICKPANELS:jl audio 5 1/4 REAR DOORS: dd components 6 1/2s HIGHS AMPS:zapco 750.2 on front doors,zapco an another 750.2 on kicks and rear doors SUBS:4-ascendant audio 18s with 5 spiders in a custom box built by KINGSUV SUB AMP: 2-dc7.5s ALTERNATORS: 3-mechmans 1- 425comp, 1-smd spec350, 1-270 with adj voltage harness on custom dc bracket WIRE:10-runs 0g front to back BATTERIES:6-d1400s TL results:157.1 at 38hz and 156.8 at headrest score @37hz. STATE AND NATIONAL RECORD IN MECA S5.
Vi sound Posted October 20, 2011 Author Report Posted October 20, 2011 Yes but why not use the reserve from the front also? If you did big 3 it will still pull from front battery Thanks bro.....I was just wounding if it would have made a diffrents that's all
XRipSticKX Posted October 21, 2011 Report Posted October 21, 2011 would make no difference where you hooked it up since the battery in the front is connected to alternator anyways... should just leave it hooked to the bat under the hood then run off that to the rear bat... make sure you have big 3 done tho NISSAN SKYLINE GTR R32 (Build in progress)Fosgate POWERhttp://www.stevemead...-fosgate-power/--------------------------------------------------------------------97 Honda AccordRockford Fosgate1400 watts RMS totalhttp://www.stevemead...e-1400watt-rms/---------------------------------------------------------------------
