Kickin' Cruiser - Stage 1, 2, & 3 - UBL
Alright, so I had a nice little break from working on my car, but it's time to get back on it. The next step is the rear speaker covers, then the front door panels. Only problem is, I ordered a new Jasper 200J circle jig, and haven't received it yet. Hopefully it will be in this week!
In the mean time, I still had this volt meter to find a place for, and the ps2 to finish installing, so lets do it!
I really want this meter to go here, but it is just too big. So later on, the plan is to fg an ipod doc into the console, at which time I will also make this meter fit properly inside. But for now, I need the use of the meter, regardless of how sh*ty it looks.
Test run for the ps2 - It works!
Oh sh*t, Medal of Honor anyone? Yeah I know, it's a ps2, but it is practically new, I already had it, and it fits like a glove!
I still need a little piece of carpet, to make it pretty, but it's in there! Volt meter too, showing the rear batt.
Kickin' Cruiser
Seller Feedback
Stage 3
Dash, Door Panels,
4th Order wall 4 - 15's
on a DC 5.0K 2 DC 5.0K's
Solo X 15 (v.2) Sub Build
And now on to todays events. I got my 140, and got first place in my class. Today was a good day!
Here is a couple of videos. The first is me doing clinics, finding my cars peak. If you pay attn, starting at 4:35 you will see me get a 141.1
And this is my single run, modified 2 class, which I could not believe I actually won w/ a 140.6! And that was after giving them back 20 seconds! Haha, not by choice. I aint gonna lie, I got lucky as hell, too many people dropped down and I was one of only four in my class. But a win is a win, and I'll take it!
Kickin' Cruiser
Seller Feedback
Stage 3
Dash, Door Panels,
So I started cutting speaker rings for the door panels.
My first speaker ring, aint she pretty!
TEST FIT!!! That is NOT the speaker I am using!!!
Let's make some more!
Kickin' Cruiser
Seller Feedback
Stage 3
Dash, Door Panels,
But then I have since changed my mind, and put the doors on hold until I do.
I figure the car's needs should come before the system. At least somewhat. So, Here is what I am about to change next
MLA - To properly charge my batts!
Front Brakes
Rotors
Bearings
Power Steering Rack
Rear Brakes
Drums
Bearings
Shocks & Struts
Complete Bushing Kit (Already own)
Tires
So Now I am acquiring parts!
Well parts are starting to come in, and I got my SMD DD-1 today!
New front brakes pads and rotors.
And we all know what this is...
Kickin' Cruiser
Seller Feedback
Stage 3
Dash, Door Panels,
So this is where I am now! :clapping:
Today, I received my MLA dual voltage control module. Here are some pics, I hope to get it installed tomorrow! My batteries should LOVE this!
Kickin' Cruiser
Seller Feedback
Stage 3
Dash, Door Panels,
Okay, so I got this baby in today, and it works like a charm! Instal was easier than I expected, and overall I am really happy with my purchase!
Here are some pics of the install!
Fist thing was get stuff out of my way!
So I could get to this
But as you can see, the wire I needed was kinda tricky to find, since there were 7 or 8 of them the exact same color!
So I decided to try the to get it right before it went into the PCM
Found it! ;)
So now some tape and care when putting it on!
And that part is pretty much done, other than a few zip ties!
So now on to a mounting location. Hmm, this looks good to me!
All cleaned up and mounted!
And how bout a jumper ground? I think so!
And there she is, fully installed!
And here is a little video I made when I first started the car after the install. Hear the fear in my voice when at first I forget to turn the HU on, which powers my volt meters!
And yeah I know, I'm a dork! That's why I hate talking in videos!
:postwhore:
Kickin' Cruiser
Seller Feedback
Stage 3
Dash, Door Panels,
Alright, I finally started on the box for the 3 12's. I have had all three for a while now, but only run two cause I'm trying to let the other one catch up now and equal them all out, before they go in the same box on the same power. It's a simple design that I am doing completely on my own, from design to construction. Subs up port back 7.5ft^3 @33hz FTW!
Here are some pics. I hope to get it completed tomorrow and ready for paint. Going w/ the same as dash (midnight black metallic)
El port
Port(left) and top/baffle(rt)
More tomorrow long as I get no setbacks! Thanks for lookin' :drinks:
Kickin' Cruiser
Seller Feedback
Stage 3
Dash, Door Panels,
Got a little more done today. Hope to get more tomorrow!
Got the port
Completely assembled, no glue.
I then took it apart and started the finally assembly. All screws were pre drilled and counter sunk. All joints glued w/Tightbond ftw!
I'll fg resin the whole inside tomorrow and cut baffle and hopefully finish assembly! Then, long as it sounds good, I'll make it pretty :clapping:
Kickin' Cruiser
Seller Feedback
Stage 3
Dash, Door Panels,
Well I got a little more done.
Got the baffle cut
And the dowel rods cut and attached to the baffle
And most of the bracing
Test fit... looks good!
Now for some Kitty Hair
Glued and ready!
Baffle glued and more Kitty Hair added! Also bracing for the baffle
And that's where I stopped for the day. Let the glue and Kitty Hair dry, and tomorrow I'll smooth it all out, finish assembly and get it all resined up inside!
In case you haven't noticed, I'm taking my time :peepwall:
Kickin' Cruiser
Seller Feedback
Stage 3
Dash, Door Panels,
Well, I got a little more done today.
Got some body filler - NOT BONDO
Then started with some sanding and test fitting...
Then I started rounding some corners - port inside
Now time to break out the dremmel and put in more bracing
I notched it out so I could "marry" the braces
Side to side is in there!
And don't forget the front to back!
Glued and screwed!
She's gettin sexy!
Now for some filler
Kickin' Cruiser
Seller Feedback
Stage 3
Dash, Door Panels,
  • Who's Online   0 Members, 0 Anonymous, 1623 Guests (See full list)
