mattp Posted October 24, 2011 Report Posted October 24, 2011 Looking to do a wall in my Tahoe 4 xl 18s on 2 Dc 5ks. Music walll would like to be in the low 30s 32 or so. The ? I have Is, what cu ft per sub should I be going for? Thanks I've got 3 of the 4 subs and one 5k should be here wed. Just need to sell my dc 7.5 to pay for the other sub and amp. Then it's go time!! Quote TEAM DC AUDIO 1999 Tahoe HU-Clarion flip out & Clarion EQS746 Mids/Highs Amp-MB QUART ONX4.125 Mids/Highs- Undecided Sub Amp-DC Audio 7.5 Subs-4x DC Audio xl 18s Alt- 270sp & 250sp Dc Power Big 3 1/0 http://dcaudio.us/ SPL-LAB sells rep. for IOWA http://spllabusa.proboards.com/
AA98hoe Posted October 24, 2011 Report Posted October 24, 2011 4-5 cubes I've tried 6 and didn't like it. I have them on 4 now and its loud Quote TEAM DC AUDIO VEHICLE:98 chevy tahoe 2wd 3-4 drop HEADUNIT:alpine 9886 PREAMP:arcaudio FRONT STAGE:4-6 1/2s selinium,DD component set and 4-selinium tweeters in each door KICKPANELS:jl audio 5 1/4 REAR DOORS: dd components 6 1/2s HIGHS AMPS:zapco 750.2 on front doors,zapco an another 750.2 on kicks and rear doors SUBS:4-ascendant audio 18s with 5 spiders in a custom box built by KINGSUV SUB AMP: 2-dc7.5s ALTERNATORS: 3-mechmans 1- 425comp, 1-smd spec350, 1-270 with adj voltage harness on custom dc bracket WIRE:10-runs 0g front to back BATTERIES:6-d1400s TL results:157.1 at 38hz and 156.8 at headrest score @37hz. STATE AND NATIONAL RECORD IN MECA S5.
mattp Posted October 24, 2011 Author Report Posted October 24, 2011 4-5 cubes I've tried 6 and didn't like it. I have them on 4 now and its loud Are u walled? I was told in a music wall to go bigger, then if just doin a box. Quote TEAM DC AUDIO 1999 Tahoe HU-Clarion flip out & Clarion EQS746 Mids/Highs Amp-MB QUART ONX4.125 Mids/Highs- Undecided Sub Amp-DC Audio 7.5 Subs-4x DC Audio xl 18s Alt- 270sp & 250sp Dc Power Big 3 1/0 http://dcaudio.us/ SPL-LAB sells rep. for IOWA http://spllabusa.proboards.com/
AA98hoe Posted October 24, 2011 Report Posted October 24, 2011 No sir I am not.... but I've seen and done a lot of testing with the xls. With your power you want control. Bigger box less control less power handleing.. that why I said up to 5c a piece Quote TEAM DC AUDIO VEHICLE:98 chevy tahoe 2wd 3-4 drop HEADUNIT:alpine 9886 PREAMP:arcaudio FRONT STAGE:4-6 1/2s selinium,DD component set and 4-selinium tweeters in each door KICKPANELS:jl audio 5 1/4 REAR DOORS: dd components 6 1/2s HIGHS AMPS:zapco 750.2 on front doors,zapco an another 750.2 on kicks and rear doors SUBS:4-ascendant audio 18s with 5 spiders in a custom box built by KINGSUV SUB AMP: 2-dc7.5s ALTERNATORS: 3-mechmans 1- 425comp, 1-smd spec350, 1-270 with adj voltage harness on custom dc bracket WIRE:10-runs 0g front to back BATTERIES:6-d1400s TL results:157.1 at 38hz and 156.8 at headrest score @37hz. STATE AND NATIONAL RECORD IN MECA S5.
mattp Posted October 24, 2011 Author Report Posted October 24, 2011 No sir I am not.... but I've seen and done a lot of testing with the xls. With your power you want control. Bigger box less control less power handleing.. that why I said up to 5c a piece Ok that's what I was thinking about 5.5cu per. Then last night was talking to some people and they said go bigger, but they have never used dcs. Ok so if I go 5.5-6 what port area would be good? Quote TEAM DC AUDIO 1999 Tahoe HU-Clarion flip out & Clarion EQS746 Mids/Highs Amp-MB QUART ONX4.125 Mids/Highs- Undecided Sub Amp-DC Audio 7.5 Subs-4x DC Audio xl 18s Alt- 270sp & 250sp Dc Power Big 3 1/0 http://dcaudio.us/ SPL-LAB sells rep. for IOWA http://spllabusa.proboards.com/
