FS: Eclipse CD8445 (8 volt HU) , AudioControl Epic-150
Eclipse 8445 8volt head unit - The head unit powers on , knobs work and light up and everything. But the display isn't working so you can't see what your doing. If you can find a faceplate it will be good as new. IIRC eBay has one for like $27. You might also be able to fix by just replacing the ribbon. Ill try looking into that. It has 4 sets of preamp out puts! REAR , FRONT and NON-FADER. It also has AUX output, CD CHANGER plugin as well as a SIRIUS plugin. Eclipse doesn't make this 8volt head unit any longer!! Comes with harness, manual, remote, mounting hardware, 2 trim rings and an extra faceplate and faceplate ribbon. . Last time I looked these sell for $399.99 new and around $250 on ebay IF you can find them. Considering there disconnected you could be hard pressed to find any on ebay. Asking Price: $200 shipped - Eclipse CD8445 pending trade
WELL I DECIDED TO JUST FIX THE ECLIPSE CD8445 HEAD UNIT. ILL HAVE IT FIXED BY THE 2ND OR SO AND ILL POST UP NEW PICS WITH IT ALL WORKING 100%. ASKING PRICE IS GOING TO GO UP DRASTICALLY THO... 8 VOLT PEROUT PUTS!!!
Specs:
ESN E8 High-Power "Customize" CD/MS Receiver with MP3/WMA playback and Remote
CD/CD-R/RW, MP3, WMA playback
MOSFET 50 watts x 4 channel power output
High 8 volt preamp outputs MAD GOOD! 8v preouts let you get louder (quicker) at lower volumes. Very rare! most units are only 2.5 to 5v.
Wireless remote included
3 pairs of preamp outputs (front, rear, and sub)
Circle Surround II Sound
E-iSERV connectivity This means when reading CDs it reads 60 seconds in advance which eliminates skipping.
Area Shot (basic map, arrow and text)
5-pattern various color illumination
Motion picture display
SIRIUS Satellite Radio Ready (tuner, antenna and subscription required and not included)
Advanced 2-mode Sound Control DSP:
7-band Parametric EQ (advanced mode on)
Speaker Time Alignment (to make the sound always sound centered to your position)
Crossover
Listening Position Selector
Multi-Harmonizer
Source Volume Control
Memory-stick ready for other MP3/WMA playback option
Advanced 24-bit Digital-to-Analog Converter
HD radio-ready (tuner required)
GPS unit-ready (GPS add-on required)
FM/AM Tuner
8-step full dot VF display
MS/CD ESN security
CD Text support
Aux input
THIS UNIT IS AN EXPENSIVE ONE. RETAILS FOR $400 AND HAS RARE 8 VOLT PREOUT PUTS!!. EVERY THING WORKS NOW 100%!!.
I popped the unit open and found that one of the capacitors broke off some how.
Which I fixed!!
I found the manual and another faceplate trim ring. You also get the extra face plate and faceplate ribbon that I bought. (To fix the original problem but ended up not needing but I switched out anyways.)
Video Of the headunit working 100%
Old video of what used to be wrong with the head unit.
These Pics where taking out of my WTT thread. If they need to be updated just let me know.
Audio Control Epic-150 - I made up a cigarette lighter hook up for it. Works great I only used this for testing voltage and how a new rated on the 150db SPL meter it has. (How close is the meter to a Termlab? I don't know, never had it tested) - Asking Price: $150 shipped
Specs:
Bass Restoration processor with SPL Display
SPL Display with Microphone Included
Para-BASS EQ
Patented Pass Restoration Circuit
Battery Voltage Indicator
Speaker Level Inputs
Balanced Differential Inputs
Edited by SojiaRaggs9000
* Eclipse CD3200 with PAC SWI-CAN2 and SW-ECL2 Steering Wheel Controls Interface
* Pioneer D-Series Mids and Highs ( Fronts: TS-D1702C; Rears; TS-D1702R and Dash; TS-D1002R )
* Rockford Fosgate PBR300X4 ( Mids and Highs Amp )
* DC 3.5k with Dual Inputs; Custom Plexiglass Backing ( Sub Amp )
* Rockford Fosgate Balanced Line Driver
* One FULLY LOADED ~ 10" DC m2 XL
* Custom Built Carpeted Ported Box Tuned to 32hz. Single Chamber With Volume of 1.44618³ ft ; 1.13216³ ft After Displacement
* Custom Built Carpeted Trunk Wall with Added Fans for Amplifier Cooling
* MechMan 240a High Output Alternator
* KnuKonceptz Krystal Kable RCA Cables
* Upgraded Electrical With 1/0 KnuKonceptz Kolossus Fleks Kable and 1/0 Sky High Car Audio Cable
* Five Exide Orbital ORB34M Marine 12 Volt Batteries
* PowerMaster XS D3100 12 Volt Battery
My 2008 Chrysler 300 Limited - SuperCharged 3.5L V6 - UBL
My Old 2005 Ford Taurus - CarDomain - Vehicle Was Sold
Is the display issue fixed now and does this have a pause option on the wireless remote?
Since were all having a moment of truth.
I hate country too..
I'd only listen to it if I got some hotass bitch in my car and shes gonna suck my dick.
Yes the display issue is fixed (which was stated above). And nah it doesn't have a "pause" button on the remote, although you can press the power button on the remote. Once the unit is turned back on it will start playing back where it left off.
I have also heard of people switching between aux and cd for starts. If I don't find something with pause soon I will get back to you.
yeah switching between modes works too. And alright man.
ttt
trade for two dual two ohm alpine type r 10s? 600w rms and 1800w peak. Only 2 months old and pushed 500w to them so no abuse. Text 225 964 1486
  • Who's Online   1 Member, 0 Anonymous, 771 Guests (See full list)
