I installed t4000.1 2 days ago , it didn't work today when I started jeep , it's not in protect , I checked coils on subs they are fine , even changed subs out , changed audio cables , the only way I can get sound out of it is in slave mode ? N e ideas ?
I'm sure you have done this but have you double checked all power and remote wiring? Have you checked your ground with a dmm? Recently I had a hard time getting mine to power on and I didn't check my ground until then. I saw it had some resistance, I figured that seat belt bolt would be fine but obviously wasn't. I switched to a bolt right next to it that had zero resistance and fixed my problem
Oh I meant checking the resistance of your ground location to neg batt terminal and not the voltage. This is something you can check with the car off. You probably will have to use a jumper extension wire for one of the probes. How exactly is your wiring layer out?
Hmm that's pretty odd. This is from the bolt to the neg batt terminal? If that's what it reads you have to switch it. You want a ground that has zero resistance. Should read 0.000. Try some other locations and post your results
  • Who's Online   0 Members, 0 Anonymous, 477 Guests (See full list)
