Okay yes at idle n while driving
I got d grounds of the frame from d seats wich I took out n grinded d paint off
N I'm not shuts Wer to get the nob so for now I'm using hifonics nob
On the gain on amp is half way.. n d nob is 3/4 up n wen turn my volume up I have to put it half way as well
try to use english please. its hard as shit to read txt tlk.
as for the knob, almost every aftermarket headunit made now a days has a built in sub level control. use that instead.
your ground seems fine. im 99% sure your amp is shutting off because of low voltage. that amp is capable of drawing in excess of 200 amps and your stock alt is probably not even half that. you need to get a new alternator. what brand and model is your car?
My bad of the shitty spelling.. its a 05 Ford f150 so I guess I'm going to have to save up for an alternator then. Right
well how low does the voltage drop exactly? a quick google reveals that your stock alt is 110 amps.
