I have a Dual hu that has 2 volt pre-outs. I have a Zx1000.1 and an RE MX18d2 (1500rms rating). The ZX puts out 1000 Watts @ 2 ohms and 500 Watts at 4 ohms. My current configuration has the ZX gain about half way and its seeing a 4ohm load from the MX18. I don't have access to oscilloscope or DD-1. My question is; Can I safely use 1 coil of my MX18 and adjust the gain as to not send full power to the sub?
i mean u cannn the whhole point of dvc is wiring options but i would never reccomend it..
BUILD LINK: http://www.stevemeadedesigns.com/board/topic/112034-2-sundown-18s-98-f-150/page__p__1565972__fromsearch__1#entry1565972
98 Ford F-150
Truck:
37" superswamper tsl radials
16" ion alloy wheels
3" body lift
2" suspension lift
Offbrand brushguard
PIAA driving lights
6000K HID's
System:
2 18" Sundown Nightshaed
Aq3500
Custom Fiberglass box
fosgate T1 6x8 Coxials
bass inferno 2000 watt 4 channel
2 XS power d3100's
0 Gauge
The coil will start to smell/smoke if it can't take the power right? My sub is inverted so I would notice right away.
its not even that. the parameters of the sub will DRASTICALLY change. either get a new sub, a new amp, or stick with what you have now.
sounds like you need to get an amp that is stable at 1ohm :drinks:
there is some VERY hard headed people out there. Anyone who says a DD-1 isnt necessary is also saying an O-scope isnt necessary. Anyone who says an O-scope IN THE MINIMUM isnt necessary, is a noob. Forget the DD-1 for a minute, any reputable installer will at LEAST use an O-scope. Those guys in that thread are clowns. Hard headed clowns.
I get you. I just can't cut the parameters in Half.
nope. when you only use one coil, you basically have a completely different woofer.
How can I get a single coil tested?
@ trigg , yeah. A 1ohm stable amp is being researched.
  • Who's Online   1 Member, 0 Anonymous, 573 Guests (See full list)
