nbshazeezee Posted November 17, 2011 Report Share Posted November 17, 2011 I currently have two Kolosal Fleks 4 gauge cables running through my car to the trunk, I wanted to throw an extra battery on deck but i dont want to change the wirring. If i hook up my two 4 gauge wires to the positive side of the battery, and ground the battery, will that give the battery as much power as one zero gauge wire?? Also what would a good battery be to run along with a 2006 honda CRV stock batt and alt. I am running an aq4x90 & an aw2200 Quote Ye dig, getting loud off little (2) AQ HDC3 12 AQ 2200D - Replaced it, Works great AQ4x90 JBL 662s 2 ways (2)XS 5100r under the hood & A 170amp alt Link to comment Share on other sites More sharing options...
LoudBimmer Posted November 17, 2011 Report Share Posted November 17, 2011 (edited) I currently have two Kolosal Fleks 4 gauge cables running through my car to the trunk, I wanted to throw an extra battery on deck but i dont want to change the wirring. If i hook up my two 4 gauge wires to the positive side of the battery, and ground the battery, will that give the battery as much power as one zero gauge wire?? Also what would a good battery be to run along with a 2006 honda CRV stock batt and alt. I am running an aq4x90 & an aw2200 4 gauge wire should be OK, but it's higly recommend to run 0 gauge. You will get more power out of your amp. Also, keep an eye on the wire, it's gonna get pretty warm. Personally, before getting secondary battery, I would change wire to 0 gauge. Edited November 17, 2011 by LoudBimmer Quote Link to comment Share on other sites More sharing options...
Mario928 Posted November 17, 2011 Report Share Posted November 17, 2011 Dont mix a stock battery and a good agm battery. You need to replace your stock battery first then buy your second battery. As for the wire just get the 0 gauge wire much easier. Here is the link were you can buy cheap and good 0 gauge http://www.hifisoundconnection.com/Shop/Control/fp/tcat/28084/SFV/30046 https://www.darvex.com/store/pc/0-Gauge-c47.htm Quote Build Under Construction Head Unit = Kenwood DDX514 Amps = Kicker 750.1, Going to install Sundown 1500D v3 and Sundown 125.4 Battery = XS D3400 Wires = Kicker RCA's, 0 Gauge street wire and Stinger Mids and Highs = Stock Sub= Kicker L7 12" Alternator = 220 Mechman Sound Deadner= Fatmat and Stinger Road Kill Link to comment Share on other sites More sharing options...
Nathan @ XSpower Posted November 17, 2011 Report Share Posted November 17, 2011 (edited) If you already have 2 4gauge wires ran now that would be fine for daily use. The battery you put in the back really is determined by how much room you have to work with. Here is a wattage chart that has the dimensions of the batteries, so you can see which best fits your needs and size. XS Power Wattage Chart If you want to change out your wire I would suggest checking out Mechman. They have some smokin prices on wire right now. Edited November 17, 2011 by Nathan@XSPOWER Quote Link to comment Share on other sites More sharing options...
