carlzz08 Posted November 17, 2011 Report Share Posted November 17, 2011 i wonder which would be best for my system.. A. Wire Parallel Primary Battery(engine bay not a car audio batt just a regular car battery) to 1 Secondary Battery(xs D3400)and Gauge 0 and Gauge 4 ALTERNATOR to second battery B. or Just put Gauge 0 and Gauge 4 FROM ALTERNATOR Going Straight to the second battery(Xs D3400)and leave the primary battery alone Quote Link to comment Share on other sites More sharing options...
Mario928 Posted November 17, 2011 Report Share Posted November 17, 2011 Dont mix a stock battery with a new battery. Quote Build Under Construction Head Unit = Kenwood DDX514 Amps = Kicker 750.1, Going to install Sundown 1500D v3 and Sundown 125.4 Battery = XS D3400 Wires = Kicker RCA's, 0 Gauge street wire and Stinger Mids and Highs = Stock Sub= Kicker L7 12" Alternator = 220 Mechman Sound Deadner= Fatmat and Stinger Road Kill Link to comment Share on other sites More sharing options...
Guest Posted November 17, 2011 Report Share Posted November 17, 2011 do big 3 (which includes alt to front battery), then 0 gauge from front battery to rear battery. done Quote Link to comment Share on other sites More sharing options...
carlzz08 Posted November 17, 2011 Author Report Share Posted November 17, 2011 @kranny: Thats exactly my current set up for my batteries Quote Link to comment Share on other sites More sharing options...
__d_a_v_i_d__ Posted November 17, 2011 Report Share Posted November 17, 2011 You can mix batt brands, but make sure the categories of the batts are the same, all AGM batteries. Then run 0g from alt to front batt, front batt parallel to back batts. grounds... etc.. best bet, is go to ur local craiglist, and search for agm batts, i see alot of Deka's, optimas, c&ds, oddysees. etcc.. and run that as ur front and then get that xs as ur backs... Quote Chevy Impala Shocker Sigs / TC Sounds 12s Sundown NS-1 | SAX 100.4 Sundown Neos | Dayton Audio Neos ETCCC ETCCC ETCCC My YouTube ---- Subcribe!! Link to comment Share on other sites More sharing options...
carlzz08 Posted November 17, 2011 Author Report Share Posted November 17, 2011 i have 2 gauge 4 from alternator to primary and 1 gauge 4 from alternator to 2nd batt.. and 1 gauge 0 from pirmary to 2nd batt i was thinking would it be better if i dont connect the primary and 2nd batt so my 3kw mono would be happy for D3400 Quote Link to comment Share on other sites More sharing options...
Mario928 Posted November 17, 2011 Report Share Posted November 17, 2011 You can mix batt brands, but make sure the categories of the batts are the same, all AGM batteries. Then run 0g from alt to front batt, front batt parallel to back batts. grounds... etc.. best bet, is go to ur local craiglist, and search for agm batts, i see alot of Deka's, optimas, c&ds, oddysees. etcc.. and run that as ur front and then get that xs as ur backs... That's what i try to say. Quote Build Under Construction Head Unit = Kenwood DDX514 Amps = Kicker 750.1, Going to install Sundown 1500D v3 and Sundown 125.4 Battery = XS D3400 Wires = Kicker RCA's, 0 Gauge street wire and Stinger Mids and Highs = Stock Sub= Kicker L7 12" Alternator = 220 Mechman Sound Deadner= Fatmat and Stinger Road Kill Link to comment Share on other sites More sharing options...
Mario928 Posted November 17, 2011 Report Share Posted November 17, 2011 i have 2 gauge 4 from alternator to primary and 1 gauge 4 from alternator to 2nd batt.. and 1 gauge 0 from pirmary to 2nd batt i was thinking would it be better if i dont connect the primary and 2nd batt so my 3kw mono would be happy for D3400 you mean running a battery with no power running to it? No you will drain the battery. Quote Build Under Construction Head Unit = Kenwood DDX514 Amps = Kicker 750.1, Going to install Sundown 1500D v3 and Sundown 125.4 Battery = XS D3400 Wires = Kicker RCA's, 0 Gauge street wire and Stinger Mids and Highs = Stock Sub= Kicker L7 12" Alternator = 220 Mechman Sound Deadner= Fatmat and Stinger Road Kill Link to comment Share on other sites More sharing options...
carlzz08 Posted November 17, 2011 Author Report Share Posted November 17, 2011 Thanks for the input david! so Option A is still best for me which is my current wiring for my batteries Quote Link to comment Share on other sites More sharing options...
Guest Posted November 17, 2011 Report Share Posted November 17, 2011 i have 2 gauge 4 from alternator to primary and 1 gauge 4 from alternator to 2nd batt.. and 1 gauge 0 from pirmary to 2nd batt i was thinking would it be better if i dont connect the primary and 2nd batt so my 3kw mono would be happy for D3400 you confuse the shit out of me the way you type your wiring. you have 2 runs of 4 gauge going from alt to front battery, then 1 run of 4 gauge from alt to 2nd battery? you dont wire the second one to the alt. you do alt to first battery, then from first battery to second battery. thats it. Quote Link to comment Share on other sites More sharing options...
