picked up some butane this mournin, got a few pics of my dash and yah
clarion cz500 head unit
Kinetik hc600
2 level 3 15s in a 4th order
mb quart 1500.1 (for now untill i get a dc 1.2k)
all knu konceptz wiring
in a 2009 ford flex
-DISKOLORED AUDIO-
-Authorized Dealer for DC Soundlab in Alaska-
why did it post 3 times?
wierd
Kinetik hc600
in a 2009 ford flex
-DISKOLORED AUDIO-
  • 1 month later...
so i redesigned my box, i have the two baffles thier so i can completely seal the sealed side and be able to remove the top off the ported side, if i have to remove the subs which i hope i wont have to..
Kinetik hc600
in a 2009 ford flex
-DISKOLORED AUDIO-
so i messed up the kerfed part, and did a regular slot port, now im jus deciding on how im gonna wire them up.. should be bangin later on in the day.. DSC00887.jpg
Kinetik hc600
in a 2009 ford flex
-DISKOLORED AUDIO-
so on the 12volt.com one coil goes into the other then to the next coil, instead of using 8 bolts as if they were direct leads, could i have just pulled all the pos to one bolt and all the negs to one bolt
http://www.the12volt.com/caraudio/woofer_configurations.asp?Q=2&I=42#results
Kinetik hc600
in a 2009 ford flex
-DISKOLORED AUDIO-
1ohm
to an mb quart 1500.1
Kinetik hc600
in a 2009 ford flex
-DISKOLORED AUDIO-
anyone got advise, this is all i need done then i can put it in the flex and record some vids for ya
Kinetik hc600
in a 2009 ford flex
-DISKOLORED AUDIO-
