AQ 2200D
Is this amp still for sale?
Product
For sale is my AQ2200D with bass knob and wire.
Was used in my truck for little less then a year powering 2 12" L7 subs upgrading soon so will no longer need this amp.
Condition
physical 9/10 (there is one scratch on the side on the amp about 2 inch long maybe)
mechanical 10/10
Specs
some info on the amp
Model AQ2200D
Digital Monoblock 1 ohm stable
Input Sensitivity 0.2v-8v
Variable Low Pass Filter 20Hz-200Hz @ 24dB/Oct
Subsonic Filter 10Hz-50Hz @ 24dB/Oct
Output Master / Input Slave, 2 amps linkable connection
Remote Level Control
Clipping Display Led
Signal to Noise Ratio 90dB
External Fuse Rating 200 Amps, 400 Amps Linked
Tested Voltage 14.4V
4 ohm power @ 12V @ 1% THD 500x 1
1 ohm power 2200 x 1
1 ohm Power @ 16V 2500 x 1
2 ohm Linked Power @ 14.4V @ 1% THD 4400 x 1
Dimensions 17.71"(L)x9.27"(W)x2.35"(H)
more can be found at http://www.audioque.com/AQ2200D-Amplifier_p_31.html
Price
Price is 320 local 340 shipped US 48
Negotiable on price to an extent
Pictures
IMG_20111211_171842.jpg?t=1323641975
