Ok so all i can use to try and figure out my box is the reaudio box cal.. I know its not the best so that's why im hoping i can get someone to help me out here. Ill post the ratios but I can't include the 45's ima put in there and sub displacement and bracing im using. If anyone could help then pls do.
Box length 42''
Box height 17.75" cause of double baffle top plate
Box width 20"
Port size 4"x 18.5" The RE cal has port length down 12.25 and long side being 28"
top depth 20"
bot depth 20"
Sub will be mounted up port up as well. I am using a crossfire xs v2 15'' and im trying to port the box to 28hz with 4.5-5cubes after displacement... If that's not possible in this box I will settle for 30hz tuning. Also for bracing I will be using wooden dowels and will resin the inside of the box and put 45's in corners and round out the bottom and top long 90's. Let me know what you guys think!
1 Crossfire XS v2 15"
2 Deka group31a's
1 XS Power D3400 (under hood)
1 Addictive Audio 500.1 :D
1 Rockford 3sixty.2
4 Crescendo pwx 6.5s
2 Pyle Pro Super tweets
1 Crescendo 1000c4
Kenwood excelon x494 Head unit
Big Three upgrade
All 0 gauge of course
1 4.56c^ft box @28hz
(New Best official db score= 151.2 @ 36hz)
Here is what i got and you can see that either RE is way off or they just cant account for a lot of stuff. This is just a quick and dirty numbers run.
"The strongest reason for people to retain the right to keep and bear arms is, as a last resort, to protect themselves against tyranny in government." -- (Thomas Jefferson)
well thank you so much for showing me that. Is there any way you could adjust the port around to see if the tuning can get a lil lower? My goal is really to be able to play pretty much all of bigpimpin's stuff..
2 Deka group31a's
1 Rockford 3sixty.2
1 Crescendo 1000c4
Big Three upgrade
ya i can but just an fyi, the lower you go the less top end you have
oh yea i know ive had boxes tuned from 38hz down to 32hz and i wanna be able to slam the low end stuff more than ever and im trying to do 145+ @32-35hz with a single 15"
2 Deka group31a's
1 Rockford 3sixty.2
1 Crescendo 1000c4
Big Three upgrade
Yes sir i just had this cross checked with Crossfire and they said it looks great for the sub if i wanna really play down that low lol. So that sounds great and thank you so much for taking the time to mess around with that for me!! :drink40:
2 Deka group31a's
1 Rockford 3sixty.2
1 Crescendo 1000c4
Big Three upgrade
Oh and if anyone looks at this.. What size wooden dowels should i use for bracing?
Ive been using allthread forever so im changing it up this time :/
2 Deka group31a's
1 Rockford 3sixty.2
1 Crescendo 1000c4
Big Three upgrade
  • Who's Online   0 Members, 0 Anonymous, 1367 Guests (See full list)
