Ported or T-Line?
Dax
I would like to know what would hit lower and get louder for my Jvc 12. It is a 350 watt rms a coil woofer, It is a dual 4. It has an FS of 25.4, and if you need to know anything else ask. Size is not a problem its goin in my room so it can be huge.
here are all the specifactions
Nominal Impedance (K) 4+4 4+4
SPL (dB,1W/1M) 88 86 SPL : Sound pressure level
Displacement (Liter) 2.13 1.83
Hole Cutout Diameter (mm) 278 235
Hole Cutout Diameter (inch) 11 9-5/16
Mounting Depth (mm) 139.6 128.3
Mounting Depth (inch) 5-17/32 5-1/16
Re (K) 3.4 3.4 Re : DC voice coil resistance
BL (T.M) 14.73 11.89 BL : Product of Flux density and Effective Voicecoil-wire length
Vas (Liter) 96.9 59.5 Vas : Volume of air equal to the driver compliance
Vas (CuFt) 3.42 2.1
Me (g) 152.9 96.6 Me : Effective mass
D (cm) 25.6 20.6 D : Effective cone diameter
Fs (Hz) 25.4 26.3 Fs : Driver free air resonance
Qms 1.7871 1.6706 Qms : Q of driver at Fs considering only non-electrical resistance
Qes 0.3819 0.3941 Qes : Q of driver at Fs considering only electrical resistance
Qts 0.3147 0.3123 Qts : Total Q of driver at Fs
Pe [max.] (W) 350 350 Pe(max) : Maximum continuous input power
Xmax.(mm) 9 9 Xmax : Maximun effective voicecoil travel without distortion
Freq.Response (Hz) 25-2 000 25-2 500
Magnet Mass (g) 1 523 1 523
Magnet Mass (oz) 53.7 53.7
Voice Coil(Aluminum)Dia. (mm) 50 50
Voice Coil(Aluminum)Dia. (inch) 2 2
Hvc (mm) 26 26 Hvc : Voice coil Height
Hag (mm) 8 8 Hag : Gap Height
Parameter CS-GW1200 CS-GW1000 HINWEISE
Nennimpedanz (K) 4+4 4+4
SPL (dB,1W/1M) 88 86 SPL : Schalldruckpegel
Volumen (Liter) 2,13 1,83
Durchmesser der Einbauöffnung (mm) 278 235
Durchmesser der Einbauöffnung (Zoll) 11 9-5/16
Einbautiefe (mm) 139,6 128,3
Einbautiefe (Zoll) 5-17/32 5-1/16
Re (K) 3,4 3,4 Re : Widerstand der Gleichspannungs-Schwingspule
BL (T.M) 14,73 11,89 BL : Produkt aus Flußdichte und effektiver Wickellänge der Schwingspule
Vas (Liter) 96,9 59,5 Vas : Luftvolumen gleich Treiber-Auslenkwert
Vas (Kubikfuß) 3,42 2,1
Me (g) 152,9 96,6 Me : Effektive Masse
D (cm) 25,6 20,6 D : Effektive Konusdurchmesser
Fs (Hz) 25,4 26,3 Fs : Treiberfreie Luftresonanz
Qms 1,7871 1,6706 Qms : Treiber-Q bei Fs, ausschließlich für nicht-elektrischen Widerstand
Qes 0,3819 0,3941 Qes : Treiber-Q bei Fs, ausschließlich für elektrischen Widerstand
Qts 0,3147 0,3123 Qts : Gesamt-Tieiber-Q bei Fs
Pe [max.] (W) 350 350 Pe[max.] : Maximale kontinuierliche Belastung
Xmax.(mm) 9 9 Xmax. : Maximale effektive Schwingspulenauslenkung ohne Verzerrung
Frequenzgang (Hz) 25-2 000 25-2 500
Magnetgewicht (g) 1 523 1 523
Magnetgewicht (oz) 53,7 53,7
Schwingspule Durchm. (mm) 50 50
Schwingspule Durchm. (Zoll) 2 2
Hvc (mm) 26 26 Hvc : Schwingspulen-höhe
Hag (mm) 8 8 Hag : Spaltbreite
Paramètres
The Midget Looks Into Your Soul
2008 Dodge am 3500HD with the 6.7 Cummins
Race Me tuner, dpf deleted
kenwood double din
cheap walmart speakers for now(infinity reference comps comps coming soon)
2 kicker L5's in a ported box of unknown tuning lol(soon to be changed)
Power acoustic 1500.1 on the subs (for now)
Ported
Vas (CuFt) 3.42 2.1
Paramètres
BASSHEADS UNITE
ok how big?
kenwood double din
  • Who's Online   0 Members, 0 Anonymous, 957 Guests (See full list)
