MIKE-2U Posted December 25, 2011 Report Posted December 25, 2011 So say i get a set of I.D. drivers, crossovers and tweeters and want to add amp to them. Do i amp the signal going to the crossover or after the cross over? and can someone explain 3 way to me and active to me ? 2006 Jeep Grand Cherokee LaredoPioneer AVH- 3200DVD2/0 Flex-A-Prene Welding Cable (2) Fully Loaded Fi Sp4's dual 1-------> My YouTube Channel <------- Needs more power those woofers will laugh at that turd
Freshman6969 Posted December 25, 2011 Report Posted December 25, 2011 an active crossover is before the amp, such as the rockford 360, passive crossovers are inbetween the mid and tweeter 3 way is a woofer, mid, tweet youd amplifiy the signal before the crossover in a passive set up Legal TL scores145.6 on the dash sealed up in the low 40hz area with the port out145.5 on the dash sealed up @30hz with the port inless then 1k clamped on a 3.5k! Why would you EVER WANT flex?huh?...flex is what can make the lows lower and more air being pushed correct? My FeedbackJeep-BuildlogPT LOSER buildlog
dohckiller808 Posted December 25, 2011 Report Posted December 25, 2011 active crossover is powered. you could do it off the amp. passive crossover uses the speaker line to filter.
MIKE-2U Posted December 25, 2011 Author Report Posted December 25, 2011 ok so if i use an amp then the crossover included with the compoents that is passive, and if i use a eq before and then the cross over that is a active ? 2006 Jeep Grand Cherokee LaredoPioneer AVH- 3200DVD2/0 Flex-A-Prene Welding Cable (2) Fully Loaded Fi Sp4's dual 1-------> My YouTube Channel <------- Needs more power those woofers will laugh at that turd
dohckiller808 Posted December 25, 2011 Report Posted December 25, 2011 active is using a deck, electronic xover on the RCA signal before its amplified. passive is after the amplifier.
MIKE-2U Posted December 25, 2011 Author Report Posted December 25, 2011 so im going to replace speakers up front first. 6.5 and tweeter, any ideas on what kind? then i wanna amp them so what setup would be the easiest. im thinking amp then crossover then the speakers i just want a crossover and amp i dont need all that e/qs and stuff. 2006 Jeep Grand Cherokee LaredoPioneer AVH- 3200DVD2/0 Flex-A-Prene Welding Cable (2) Fully Loaded Fi Sp4's dual 1-------> My YouTube Channel <------- Needs more power those woofers will laugh at that turd
