1988JimmyRE Posted December 25, 2011 Report Posted December 25, 2011 I have a Fusion Powerplant fp-504 4 Channel amp now. Everything was hooked up right in my buddys truck, he left for the Marines and he came back after driving around a few days 1 speaker was working... out of 6. I checked it out 1 speaker was blown that was on the left Rear. the right rear worked. The dash and door speakers were wired together on the front left and right, so 2ohm each, while the back being at 4 ohm each, (i'm fairly sure this doesn't matter) anyway heres whats happening LEFT FRONT makes a popping/humming/distorted nightmare sound. RIGHT FRONT does not produce sound at all. LEFT AND RIGHT REAR work as far as i can tell any ideas on cheap fix? BUILD LOG-->1988 S15 Jimmy V8 4x4 2 15" RE Audio<--BUILD LOG
evermaxx Posted December 25, 2011 Report Posted December 25, 2011 Check your connections.. Sounds like your front channels burned out. Open it up & check for burnt. Team Subsonic Lows Get your garbage EMF products of my amp bitch Man....it makes a nice work bench
1988JimmyRE Posted December 25, 2011 Author Report Posted December 25, 2011 Check your connections.. Sounds like your front channels burned out. Open it up & check for burnt. Uploading pictures now, absolutely no burns everything looks great BUILD LOG-->1988 S15 Jimmy V8 4x4 2 15" RE Audio<--BUILD LOG
1988JimmyRE Posted December 25, 2011 Author Report Posted December 25, 2011 pictures are now uploaded BUILD LOG-->1988 S15 Jimmy V8 4x4 2 15" RE Audio<--BUILD LOG
1988JimmyRE Posted December 26, 2011 Author Report Posted December 26, 2011 could i run this and only use the rear channels? BUILD LOG-->1988 S15 Jimmy V8 4x4 2 15" RE Audio<--BUILD LOG
