Brian2435 Posted January 9, 2012 Report Posted January 9, 2012 so im gonna wire up two home speakers (8 ohms each) to a car amplifier(because they're rms rating is more than i can find home receivers for without spending over $300) so i was just gonna hook up a car amp in my house to power them. so i have two questions: 1. is the only way to get a true left and right sound from the speakers is to hook them up to a 2 channel amplifier? im pretty sure you cant bridge the two speakers to one monoblock or bridge them to 2 channels each on a 4 channel amp, because it would be giving the speakers the same output, not left and right. 2. is there any negative to wire 8 ohm speakers to a car amp channel, because most dont rate the amplifier at 8 ohms, typically 4 ohms or lower. would this only just reduce the power output of the amplifier? Quote
Brian2435 Posted January 9, 2012 Author Report Posted January 9, 2012 I just realized, could I bridge the 2 left speaker outputs to power the left speaker, while doing the same but with the right speaker on a 4 channel amp? Quote
wadewills Posted January 10, 2012 Report Posted January 10, 2012 Bridge channels 1 and 2 on the 4 channel amp and plug to left speaker. Bridge 3 and 4 channel and plug to right speaker. Use RCA splitter and put red RCA to both plugs for channels 3 and 4. Use another RCA splitter and put white RCA to both plugs for channels 1 and 2. This will give you true left and right with decent power out of the amp. Quote Current Set-Up 2004 Chevy Tahoe Subs: 2 DC XL 15's Box: 8.5 ft^3 @ 38hz Amp: Amrican Bass VFL 500.1 Alt: Db Electric 250amp Batts: 2 Kinetic HC 1200s Radio: Pioneer 3300UB Doors: Pyle Pro Mids/Goldwood Tweets Amp: Alpine MRP-300/Hifonics ZX80.4 Wire: Kicker 1/0 Guage Termlab: 153.1 Outlaw Style @ 46HZ
Brian2435 Posted January 10, 2012 Author Report Posted January 10, 2012 Bridge channels 1 and 2 on the 4 channel amp and plug to left speaker. Bridge 3 and 4 channel and plug to right speaker. Use RCA splitter and put red RCA to both plugs for channels 3 and 4. Use another RCA splitter and put white RCA to both plugs for channels 1 and 2. This will give you true left and right with decent power out of the amp. Oh I didn't even think of that. Thanks a lot Quote
wadewills Posted January 10, 2012 Report Posted January 10, 2012 Glad to help and good luck! Quote Current Set-Up 2004 Chevy Tahoe Subs: 2 DC XL 15's Box: 8.5 ft^3 @ 38hz Amp: Amrican Bass VFL 500.1 Alt: Db Electric 250amp Batts: 2 Kinetic HC 1200s Radio: Pioneer 3300UB Doors: Pyle Pro Mids/Goldwood Tweets Amp: Alpine MRP-300/Hifonics ZX80.4 Wire: Kicker 1/0 Guage Termlab: 153.1 Outlaw Style @ 46HZ
