veedubmulisha43 Posted January 10, 2012 Report Posted January 10, 2012 I need to know if running speaker wire from my bass amp and then my mids and high amp will interfear? i know ur not supposed to run them by power lines but will other speaker wires mess up signals? or can i tie strands of them together to run down the car? same with rcas? if ones bass and i have a mids and highs rca strand next to eachother will that screw up signals?
MIKE-2U Posted January 10, 2012 Report Posted January 10, 2012 speaker wires SHOULD be ok but if you can avoid it i would. Not a good Habit 2006 Jeep Grand Cherokee LaredoPioneer AVH- 3200DVD2/0 Flex-A-Prene Welding Cable (2) Fully Loaded Fi Sp4's dual 1-------> My YouTube Channel <------- Needs more power those woofers will laugh at that turd
veedubmulisha43 Posted January 10, 2012 Author Report Posted January 10, 2012 Ok cool, cause they dont seem affected right now but pretty soon im gona have to cross a bass rca set with a mids and high set to go into the amp but il keep them away as much as i can and then leaving the amp they will be near to
MIKE-2U Posted January 10, 2012 Report Posted January 10, 2012 when i had my sub rcas next to power no issues. but once i ran the rear stage ones i heard the noise. SO i moved BOTH rcas to opposite side of car. Reason for this is because a sub puts out lower fq and those fq can not be heard threw your subs but can be heard through your speakers. 2006 Jeep Grand Cherokee LaredoPioneer AVH- 3200DVD2/0 Flex-A-Prene Welding Cable (2) Fully Loaded Fi Sp4's dual 1-------> My YouTube Channel <------- Needs more power those woofers will laugh at that turd
veedubmulisha43 Posted January 11, 2012 Author Report Posted January 11, 2012 ok. cool, thanks yea i hear oh dont run wire by ur power after i did and im like dam.. but its fine but cause its my sub, ok when i add again il rearange
