Luken Posted January 25, 2012 Author Report Share Posted January 25, 2012 wire them down to 2 ohm? it would end up being 1 door per channel roughly, but you would want to set your components up for right and left. That would eliminate the need for your second amp. Does your mono amp have an rca out? if so just use that it said these speakers arent recommended for 2 ohm but idk. and 1 channel per door wont be enough power. it's 2 6.5's and 2 tweeters per set Quote Link to comment Share on other sites More sharing options...
ALEX 323 Posted January 25, 2012 Report Share Posted January 25, 2012 (edited) sorry double Edited January 25, 2012 by ALEX 323 Quote aka KHRISS Link to comment Share on other sites More sharing options...
ALEX 323 Posted January 25, 2012 Report Share Posted January 25, 2012 (edited) Edited January 25, 2012 by ALEX 323 Quote aka KHRISS Link to comment Share on other sites More sharing options...
ALEX 323 Posted January 25, 2012 Report Share Posted January 25, 2012 get a audiocontrol MATRIX its a line driver since its a one RCA output H/U im guessing 2 volt if lucky the MATRIX makes your 1 RCA output to a 8 volt output times 3 for 3 amps giving you a better signal to your amps better signal = better sound quality Quote aka KHRISS Link to comment Share on other sites More sharing options...
Luken Posted January 25, 2012 Author Report Share Posted January 25, 2012 get a audiocontrol MATRIX its a line driver since its a one RCA output H/U im guessing 2 volt if lucky the MATRIX makes your 1 RCA output to a 8 volt output times 3 for 3 amps giving you a better signal to your amps better signal = better sound quality Thanks for the help. and i have 2 RCA outputs not 1 Quote Link to comment Share on other sites More sharing options...
