white4d96 Posted February 1, 2012 Report Posted February 1, 2012 I am running a Massive NX4 for my mids and highs. Everything's run at a 4 ohm load, plently of voltage, gains set at about 1/3 with a Pioneer 3300bt as source unit. After about a half hour of hard use the mids and highs amp goes into protect and is warm to the touch. At the moment I have it mounted directly to a board on the trunk floor. I was thinking about using some standoffs to get it off the floor, but wasn't sure if that would be enough. Anyone else run this amp and have this issue? Should I be considering active cooling? Too many projects, too little time...
timwebb Posted February 1, 2012 Report Posted February 1, 2012 ebay had some fan kits for amps cheap.
Rebel4055 Posted February 1, 2012 Report Posted February 1, 2012 How is the ground to the amp? I would think it would be hotter than just warm if it went into protect? Rest In Peace mother. January 22, 1955 - February 14, 2013 http://www.stevemeadedesigns.com/board/user/35351-megrch/
white4d96 Posted February 2, 2012 Author Report Posted February 2, 2012 It certainly isn't burn-your-hand hot, but it is abnormally warm when it goes into protect. It's grounded straight to the batt which is like 15 inches away. Too many projects, too little time...
