mathewdylang Posted February 6, 2012 Report Share Posted February 6, 2012 if your volt meter is hooked to the front battery, and the amp is hooked to the rear with no ground you wont see voltage drop of the front battery. it just sucked the juice your rear battery had in it. Quote Link to comment Share on other sites More sharing options...
Rebel4055 Posted February 6, 2012 Report Share Posted February 6, 2012 DId you sand the paint away from it? Quote Rest In Peace mother. January 22, 1955 - February 14, 2013 http://www.stevemeadedesigns.com/board/user/35351-megrch/ Link to comment Share on other sites More sharing options...
ShaneBond Posted February 6, 2012 Author Report Share Posted February 6, 2012 well its the stock one on the blazer's dash. it did it with the audiopipe 1800 but not the 3000... Quote Link to comment Share on other sites More sharing options...
tacomabanga1986 Posted February 6, 2012 Report Share Posted February 6, 2012 ied check all connections too, could be either a bad ground or maby speaker wires came loose and throwing it into protect i dunno how u went up in power and no voltage drop, is it louder to ear and what ohm load do u have it at? try to wire it at a higher ohm load just to see what that does and if u have a mids n highs amp does it cut off too? mine would start to get distorted with voltage drop with my old stinger battery, the new c&d and not much of a voltage drop at all, still around 13.8v down to no less than 13.2v at "full tilt" oh, and with how u got it wired u need it, front battery, fuse, fuse, rear battery and then amp, the reason for the second fuse is to fuse the power comeing back threw the power wire i guess when car is off and what knot check voltage at amp too with a dmm (digital multi meter) and see what it goes to Quote here's a link to my system 99 toyota tacoma , 2 mtx 8000 1504's in a sealed downfire , 1000w memphis amp here's a link to my other system my 90 geo prizm test car heres a thread i got of new songs u can dl that are legal = Some Good Bangage/you Can Dl These Free And Legit Link to comment Share on other sites More sharing options...
ShaneBond Posted February 6, 2012 Author Report Share Posted February 6, 2012 DId you sand the paint away from it? no it was some spray on rhino liner Quote Link to comment Share on other sites More sharing options...
ShaneBond Posted February 6, 2012 Author Report Share Posted February 6, 2012 ied check all connections too, could be either a bad ground or maby speaker wires came loose and throwing it into protect i dunno how u went up in power and no voltage drop, is it louder to ear and what ohm load do u have it at? try to wire it at a higher ohm load just to see what that does and if u have a mids n highs amp does it cut off too? mine would start to get distorted with voltage drop with my old stinger battery, the new c&d and not much of a voltage drop at all, still around 13.8v down to no less than 13.2v at "full tilt" oh, and with how u got it wired u need it, front battery, fuse, fuse, rear battery and then amp, the reason for the second fuse is to fuse the power comeing back threw the power wire i guess when car is off and what knot check voltage at amp too with a dmm (digital multi meter) and see what it goes to it cant be the speaker cable i wire nutted them and wrapped in about a pound of electric tape each and its at 2 ohms. and my mids and highs amp would keep running... Quote Link to comment Share on other sites More sharing options...
Rebel4055 Posted February 6, 2012 Report Share Posted February 6, 2012 I meant the ground location. And the volt meter on the dash is not accurate. A aftermarket voltmeter to the rear battery would be ideal. Quote Rest In Peace mother. January 22, 1955 - February 14, 2013 http://www.stevemeadedesigns.com/board/user/35351-megrch/ Link to comment Share on other sites More sharing options...
tacomabanga1986 Posted February 6, 2012 Report Share Posted February 6, 2012 DId you sand the paint away from it? no it was some spray on rhino liner i think he ment where the ground was, most of those bolts are just to sheet metal with a nut welded on the back side, thats how i got mine wired for now, it works but it could be better try to sand where ground wire is and being the box is on it it could of wiggled loose, ied move it to a place that doesn't get to much movement Quote here's a link to my system 99 toyota tacoma , 2 mtx 8000 1504's in a sealed downfire , 1000w memphis amp here's a link to my other system my 90 geo prizm test car heres a thread i got of new songs u can dl that are legal = Some Good Bangage/you Can Dl These Free And Legit Link to comment Share on other sites More sharing options...
ShaneBond Posted February 6, 2012 Author Report Share Posted February 6, 2012 I meant the ground location. And the volt meter on the dash is not accurate. A aftermarket voltmeter to the rear battery would be ideal. oh and yes but idk if its a good ground or not it looks good. that will be my next investment but even for accuracy shouldnt it move some with the new amp? i didnt change anything other than the amp with the new system and it went from dimming lights to none at all and constant power to the dash at least. Quote Link to comment Share on other sites More sharing options...
mathewdylang Posted February 6, 2012 Report Share Posted February 6, 2012 even then, the voltage gauge in the dash is wired to the front battery only. if you ground is bad (like being on top of rhino lining) your rear battery isnt "hooked up" you arent seeing voltage drop because your rear battery isnt in the same wiring line as the front and voltage gauge itself. your rear amp worked for a few minutes using only what the battery had stored power wise. it will go into protect when it reaches below 9.6v. IE your battery in the rear is drained with now charge coming from the alt because no ground. Quote Link to comment Share on other sites More sharing options...
