STEvil Posted February 8, 2012 Report Posted February 8, 2012 (edited) No Matters little really as long as both subs are pushing in the same direction. Phase is really important when you have some subs inverted, and some not. No, if you have one inverted and one not, you need to switch the + and - on one of the subs. Change phase on a HU or amp switches all + and -, so it will not change a thing unless you wire them correctly. Methinks you should understand better before trying to correct. What he said was correct, what you said was also correct but did not differentiate between the phase switch and swapping leads, which honestly has been answered 1000 times already anyways.... The phase switch(es) are only to be used when all drivers are facing the same way, assuming single-amp configuration. If inverting some drivers and leaving others normal then you must swap the positive and negative leads to keep them in phase with each other. As to the correct position of the phase switch, it should be tested at both 0 and 180 in any configuration. Weird things do happen.. Edited February 8, 2012 by STEvil Quote MickyMcD - "Capable of making some serious trouser flapping volumes at where's-my-testicles frequencies, the Servo-Drives used to be fairly jaw dropping..." Any time you have have a power wire next to your frame put some rubber hosing (or cut up an innertube) around it. The wire is bound to wiggle (due to driving or flex) and the casing will eventually wear through. Hammerdown... 1% no links to outside websites, business related FB/YT pages allowed.
