Posted (edited)
http://www.the12volt...=2&I=41#results
which are they wired like? nvm ninjaed
mess with the settings on the amp
Edited by Freshman6969
Legal TL scores145.6 on the dash sealed up in the low 40hz area with the port out145.5 on the dash sealed up @30hz with the port inless then 1k clamped on a 3.5k!
Why would you EVER WANT flex?
huh?...flex is what can make the lows lower and more air being pushed correct?
me_zps0fb5a5b4.jpgMy FeedbackJeep-BuildlogPT LOSER buildlog
The box is a simple prefab and well it works well enough when the subs are solo. They're just really, really quiet together. Not nasty sounding.
that's the problem then, prefab. always make your own box so you know the tuning of it. but it very well may be the wiring problem too
#teamihop
Two 12 inch DC XL's
Carbon Fiber Cap
Stetsom 7k
Shell of box / baffle built by me
Port / sealing the box by John Hone
Fuck midrange
Alpine-9886
http://www.stevemeadedesigns.com/board/topic/177428-97jettas-sql-trunk-wall-loudest-99-buick-century-custom-with-a-one-legged-owner/
price has no influence on how something sounds
I told him to move the fucking port.
they see me hoppin they stoppin they can't believe im so white and dirty
It looks like you got so drunk, that someone came up and stole your leg.
Posted (edited)
since i have nothing better to do.....prefabs do indeed suck, but there good for the simple install, small power, low power subs, other then that they suck, its most likly the wiring, or the settings on the amp
im pretty sure on that amp theres a subsonic setting, mess with that, as well as the crossover or LPF, is the amp switched to LP(low pass), not HP(high pass) or FR(full range)
I'm a audio genius but that's what i've learned. that's why i also said it could be wiring :P i'm not disrespecting, but just saying. and with the system he has, i was thinking that the box was the issue lol. but that's just my .02$
#teamihop
Two 12 inch DC XL's
Carbon Fiber Cap
Stetsom 7k
Fuck midrange
Alpine-9886
The options on the back are the gain, the punch bass or something, and the phase. I don't know about them. But, I figured they were fine since the subs sound fine solo.
whats the gain at? the punch bass is (bass boost) you can turn it up a tad, like to 1 or 2 but not much more, thats just asking for clipping, is the phase at 0 degrees?
the gain knob isn't a volume knob. it just tunes in with the subs, if i remember correctly. (currently drunk)
#teamihop
Two 12 inch DC XL's
Carbon Fiber Cap
Stetsom 7k
Fuck midrange
Alpine-9886
