Freshman6969 Posted February 12, 2012 Report Share Posted February 12, 2012 (edited) http://www.the12volt...=2&I=41#results which are they wired like? nvm ninjaed mess with the settings on the amp Edited February 12, 2012 by Freshman6969 Quote Legal TL scores145.6 on the dash sealed up in the low 40hz area with the port out145.5 on the dash sealed up @30hz with the port inless then 1k clamped on a 3.5k! Why would you EVER WANT flex?huh?...flex is what can make the lows lower and more air being pushed correct? My FeedbackJeep-BuildlogPT LOSER buildlog Link to comment Share on other sites More sharing options...
97Jetta1637 Posted February 12, 2012 Report Share Posted February 12, 2012 The box is a simple prefab and well it works well enough when the subs are solo. They're just really, really quiet together. Not nasty sounding. that's the problem then, prefab. always make your own box so you know the tuning of it. but it very well may be the wiring problem too Quote #teamihop Two 12 inch DC XL's Carbon Fiber Cap Stetsom 7k Shell of box / baffle built by me Port / sealing the box by John Hone Fuck midrange Alpine-9886 http://www.stevemeadedesigns.com/board/topic/177428-97jettas-sql-trunk-wall-loudest-99-buick-century-custom-with-a-one-legged-owner/ price has no influence on how something sounds I told him to move the fucking port. they see me hoppin they stoppin they can't believe im so white and dirty It looks like you got so drunk, that someone came up and stole your leg. Link to comment Share on other sites More sharing options...
p.flint Posted February 12, 2012 Author Report Share Posted February 12, 2012 I believe it's a 2 Ohm load. Quote Link to comment Share on other sites More sharing options...
Freshman6969 Posted February 12, 2012 Report Share Posted February 12, 2012 (edited) The box is a simple prefab and well it works well enough when the subs are solo. They're just really, really quiet together. Not nasty sounding. that's the problem then, prefab. always make your own box so you know the tuning of it. but it very well may be the wiring problem too since i have nothing better to do.....prefabs do indeed suck, but there good for the simple install, small power, low power subs, other then that they suck, its most likly the wiring, or the settings on the amp im pretty sure on that amp theres a subsonic setting, mess with that, as well as the crossover or LPF, is the amp switched to LP(low pass), not HP(high pass) or FR(full range) Edited February 12, 2012 by Freshman6969 Quote Legal TL scores145.6 on the dash sealed up in the low 40hz area with the port out145.5 on the dash sealed up @30hz with the port inless then 1k clamped on a 3.5k! Why would you EVER WANT flex?huh?...flex is what can make the lows lower and more air being pushed correct? My FeedbackJeep-BuildlogPT LOSER buildlog Link to comment Share on other sites More sharing options...
p.flint Posted February 12, 2012 Author Report Share Posted February 12, 2012 It's option 1- in parallel, not series. Quote Link to comment Share on other sites More sharing options...
97Jetta1637 Posted February 12, 2012 Report Share Posted February 12, 2012 The box is a simple prefab and well it works well enough when the subs are solo. They're just really, really quiet together. Not nasty sounding. that's the problem then, prefab. always make your own box so you know the tuning of it. but it very well may be the wiring problem too since i have nothing better to do.....prefabs do indeed suck, but there good for the simple install, small power, low power subs, other then that they suck, its most likly the wiring, or the settings on the amp I'm a audio genius but that's what i've learned. that's why i also said it could be wiring i'm not disrespecting, but just saying. and with the system he has, i was thinking that the box was the issue lol. but that's just my .02$ Quote #teamihop Two 12 inch DC XL's Carbon Fiber Cap Stetsom 7k Shell of box / baffle built by me Port / sealing the box by John Hone Fuck midrange Alpine-9886 http://www.stevemeadedesigns.com/board/topic/177428-97jettas-sql-trunk-wall-loudest-99-buick-century-custom-with-a-one-legged-owner/ price has no influence on how something sounds I told him to move the fucking port. they see me hoppin they stoppin they can't believe im so white and dirty It looks like you got so drunk, that someone came up and stole your leg. Link to comment Share on other sites More sharing options...
p.flint Posted February 12, 2012 Author Report Share Posted February 12, 2012 The options on the back are the gain, the punch bass or something, and the phase. I don't know about them. But, I figured they were fine since the subs sound fine solo. Quote Link to comment Share on other sites More sharing options...
Freshman6969 Posted February 12, 2012 Report Share Posted February 12, 2012 The options on the back are the gain, the punch bass or something, and the phase. I don't know about them. But, I figured they were fine since the subs sound fine solo. whats the gain at? the punch bass is (bass boost) you can turn it up a tad, like to 1 or 2 but not much more, thats just asking for clipping, is the phase at 0 degrees? Quote Legal TL scores145.6 on the dash sealed up in the low 40hz area with the port out145.5 on the dash sealed up @30hz with the port inless then 1k clamped on a 3.5k! Why would you EVER WANT flex?huh?...flex is what can make the lows lower and more air being pushed correct? My FeedbackJeep-BuildlogPT LOSER buildlog Link to comment Share on other sites More sharing options...
p.flint Posted February 12, 2012 Author Report Share Posted February 12, 2012 The gain is full (cause I'm not getting loud sound!) & ahh. I see. & I believe so it's either that or 180. What is phase anyways? Quote Link to comment Share on other sites More sharing options...
97Jetta1637 Posted February 12, 2012 Report Share Posted February 12, 2012 the gain knob isn't a volume knob. it just tunes in with the subs, if i remember correctly. (currently drunk) Quote #teamihop Two 12 inch DC XL's Carbon Fiber Cap Stetsom 7k Shell of box / baffle built by me Port / sealing the box by John Hone Fuck midrange Alpine-9886 http://www.stevemeadedesigns.com/board/topic/177428-97jettas-sql-trunk-wall-loudest-99-buick-century-custom-with-a-one-legged-owner/ price has no influence on how something sounds I told him to move the fucking port. they see me hoppin they stoppin they can't believe im so white and dirty It looks like you got so drunk, that someone came up and stole your leg. Link to comment Share on other sites More sharing options...
