p.flint Posted February 12, 2012 Author Report Share Posted February 12, 2012 Near St. Joseph, MO. But I'm busy tomorrow. I have 2 amps, could that be it? Or like not sufficient battery power or anything? The one amp only runs the 6x9's & door speakers. Quote Link to comment Share on other sites More sharing options...
97Jetta1637 Posted February 12, 2012 Report Share Posted February 12, 2012 Hm, it could be gains, or voltage drop. Have you done the big three? what is you alt/batt looking like, stock or upgraded? Quote #teamihop Two 12 inch DC XL's Carbon Fiber Cap Stetsom 7k Shell of box / baffle built by me Port / sealing the box by John Hone Fuck midrange Alpine-9886 http://www.stevemeadedesigns.com/board/topic/177428-97jettas-sql-trunk-wall-loudest-99-buick-century-custom-with-a-one-legged-owner/ price has no influence on how something sounds I told him to move the fucking port. they see me hoppin they stoppin they can't believe im so white and dirty It looks like you got so drunk, that someone came up and stole your leg. Link to comment Share on other sites More sharing options...
Freshman6969 Posted February 12, 2012 Report Share Posted February 12, 2012 (edited) Hm, it could be gains, or voltage drop. Have you done the big three? what is you alt/batt looking like, stock or upgraded? its not either...im still gunna with with wiring, OP take ALL the wiring off your subs, and re do them according to the link i posted http://www.the12volt...=2&I=41#results and make sure your connections are good when you hook the wire up to the subs, if they have those tabs, use female connectors, if they have the push ones, make sure your grabbing the wire, not the plastic Edited February 12, 2012 by Freshman6969 Quote Legal TL scores145.6 on the dash sealed up in the low 40hz area with the port out145.5 on the dash sealed up @30hz with the port inless then 1k clamped on a 3.5k! Why would you EVER WANT flex?huh?...flex is what can make the lows lower and more air being pushed correct? My FeedbackJeep-BuildlogPT LOSER buildlog Link to comment Share on other sites More sharing options...
97Jetta1637 Posted February 12, 2012 Report Share Posted February 12, 2012 Hm, it could be gains, or voltage drop. Have you done the big three? what is you alt/batt looking like, stock or upgraded? its not either...im still gunna with with wiring, OP take ALL the wiring off your subs, and re do them according to the link i posted http://www.the12volt...=2&I=41#results and make sure your connections are good when you hook the wire up to the subs, if they have those tabs, use female connectors, if they have the push ones, make sure your grabbing the wire, not the plastic follow his link. personally I'm only throwing out suggestions. this guy is more knowledgable than me. Quote #teamihop Two 12 inch DC XL's Carbon Fiber Cap Stetsom 7k Shell of box / baffle built by me Port / sealing the box by John Hone Fuck midrange Alpine-9886 http://www.stevemeadedesigns.com/board/topic/177428-97jettas-sql-trunk-wall-loudest-99-buick-century-custom-with-a-one-legged-owner/ price has no influence on how something sounds I told him to move the fucking port. they see me hoppin they stoppin they can't believe im so white and dirty It looks like you got so drunk, that someone came up and stole your leg. Link to comment Share on other sites More sharing options...
p.flint Posted February 12, 2012 Author Report Share Posted February 12, 2012 Voltage drop? It's stock alt/battery. & believe me, I've checked and rechecked a dozen times. All the polarity is correct and it is in parallel circuit. Quote Link to comment Share on other sites More sharing options...
Freshman6969 Posted February 12, 2012 Report Share Posted February 12, 2012 Voltage drop? It's stock alt/battery. & believe me, I've checked and rechecked a dozen times. All the polarity is correct and it is in parallel circuit. no harm in trying one last time, could be a bad wire too, try new or diffrent wire Quote Legal TL scores145.6 on the dash sealed up in the low 40hz area with the port out145.5 on the dash sealed up @30hz with the port inless then 1k clamped on a 3.5k! Why would you EVER WANT flex?huh?...flex is what can make the lows lower and more air being pushed correct? My FeedbackJeep-BuildlogPT LOSER buildlog Link to comment Share on other sites More sharing options...
p.flint Posted February 12, 2012 Author Report Share Posted February 12, 2012 They play, just they're definitely not 500 watts. The wires are all good. Quote Link to comment Share on other sites More sharing options...
Freshman6969 Posted February 12, 2012 Report Share Posted February 12, 2012 welp, im outta ideas, im done for the night, if you have any more questions feel free to PM me Quote Legal TL scores145.6 on the dash sealed up in the low 40hz area with the port out145.5 on the dash sealed up @30hz with the port inless then 1k clamped on a 3.5k! Why would you EVER WANT flex?huh?...flex is what can make the lows lower and more air being pushed correct? My FeedbackJeep-BuildlogPT LOSER buildlog Link to comment Share on other sites More sharing options...
p.flint Posted February 12, 2012 Author Report Share Posted February 12, 2012 Thanks! Quote Link to comment Share on other sites More sharing options...
