DC Sound Lab
Team Belgium, playing with DC audio...
Hello, I'm a small shop from Belgium (Europe), and for sure we want to supply you some pics and vids from our cars to. We do it mostly for the hobby, but if we play in competition then we play in the 'propper droppers' competition. it is getting the biggest score on 20-25-33-40hz. quite low you can say :P
Enough chatted, here are the first pics (I'm not going to post all the pics from my clients, but if there are questions, for sure, just ask!)
Opel vectra break:
system setup for this year:
2x DC audio level5 18" on a 9k, 360Ah of kinetik power batteries.
later on we want to go to a massive frontsystem (+/- 900w rms on each door) and the client wants to go to 4x18" level 5 and 2 9k amps...
the start of the building
Sqoda octavia break:
system setup:
- 4x µ dimension kick/door
- tweeter + mid from µ dimension
- 2x600w rms on the kicks (will be upgraded this season to 2x900w rms!)
- 4x150w rms on the mid/tweet
- ground zero 6500w rms amp @1ohm
- DC audio level5 18" sub
the doors:
lipje gemaakt om aansluiting beter te doen verlopen
dan houten constructie en schuimen maar!
poly werk, lipje er ook terug aan bevestigen alsook draadstangen voor bevestiging in de deuren
en heel wat aanpassen
love the proper droppers format. i wish it would make its way over here
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
me to. I in fact don't like the usual spl formats. because to score is it better to have a portfrequenty that is quite high... daily, you can't enjoy your install then... for this you need to tune your portfrequenty low (20-23hz) and for sure then you can enjoy the installation in the week also...
thx guys.
we always want damp as much as possible. I don't like shaking windows/roofs, because it costs a lot and for sure it reduces the output on low frequenties.
I'm using for that a special 2 component pasta + metal plates to make a clean solid roof...
the more woofers/power the car gets, the more material we have to add.
an example of the sqoda octavia break:
the opel vectra (with in total 4x18") will get a solid roof with 36mm mdf against it :D
  • Who's Online   1 Member, 0 Anonymous, 1659 Guests (See full list)
