Simple question
Kickercivic
Just got my new amp today its a re audio xt-4000dev3. i didnt now that the amp had a master and slave setting on it. new to car audio still learning. so i tryed to look up witch way id want the switch and all i could find was stuff on hooking 2 amps together. from that tho im guesse i want to have the amp set on master unless im hooking up a secound then one has to be in slave?
Also what is the phase setting for it 0degress to 180. how do i set that?
Amp is the master. slave is if you link two together. set that to master. the phase is if you have some subs inverted and some nornal.
Switch = Master
Phase = Off ( Zero)
LP = 80 hz
Gain = set with Oscope or DD-1
bass boost = off.
Learn alot off of this site bro, welcome to the forums.
2006 Jeep Grand Cherokee LaredoPioneer AVH- 3200DVD2/0 Flex-A-Prene Welding Cable
(2) Fully Loaded Fi Sp4's dual 1-------> My YouTube Channel <-------
Needs more power those woofers will laugh at that turd
if you have to ask about strapping amps together, you shouldnt even fucking attempt it. keep the switch on Master. dont bother with phase, just keep it on 0.
Switch = Master
Phase = Off ( Zero)
LP = 80 hz
bass boost = off.
thanks alot
im not looking to stramp it to another amp(maybe in the future) didnt even know the amp had that setting till i got it today. thannk u also
  • Who's Online   0 Members, 0 Anonymous, 1111 Guests (See full list)
