Loslam Posted March 6, 2012 Report Share Posted March 6, 2012 For a trunk car non-sealed up yes port back is loudest most of the time. The car it is going in was never mentioned so I just did that port to cover a lot of applications Thats fine! I was just making sure, makes perfect sense. one day you will have to teach me to use google sketch up like that! haha and im assuming the bottem piece is 30x18 aswell? Yep, bottom piece is 18x30 making it one of the walls for the port. And google sketchup is very easy just make the dimensions of your piece of wood then use the 'push/pull' button and do .75 (or whatever thickness your wood is) Quote 1997 Chevrolet Silverado Extended Cab, 350 Vortec Things to come at some point... Build Log: http://www.stevemead...2200ds-133-ohm/ Link to comment Share on other sites More sharing options...
BillKessel Posted March 6, 2012 Author Report Share Posted March 6, 2012 For a trunk car non-sealed up yes port back is loudest most of the time. The car it is going in was never mentioned so I just did that port to cover a lot of applications Thats fine! I was just making sure, makes perfect sense. one day you will have to teach me to use google sketch up like that! haha and im assuming the bottem piece is 30x18 aswell? Yep, bottom piece is 18x30 making it one of the walls for the port. And google sketchup is very easy just make the dimensions of your piece of wood then use the 'push/pull' button and do .75 (or whatever thickness your wood is) Ive played with it but getting the dimensions of the box was what was holding me up, im sure id do decent if i had a set of dimensions... and knew how to read them lol Quote Link to comment Share on other sites More sharing options...
Loslam Posted March 6, 2012 Report Share Posted March 6, 2012 Like 412 CVX said, download torres box calculator and play around until you find a set of dimensions that will work for you and then there's the dimensions for you to make in sketchup. Quote 1997 Chevrolet Silverado Extended Cab, 350 Vortec Things to come at some point... Build Log: http://www.stevemead...2200ds-133-ohm/ Link to comment Share on other sites More sharing options...
BillKessel Posted March 6, 2012 Author Report Share Posted March 6, 2012 Like 412 CVX said, download torres box calculator and play around until you find a set of dimensions that will work for you and then there's the dimensions for you to make in sketchup. Aright well thanks for your help. Life saver for sure haha Quote Link to comment Share on other sites More sharing options...
